Thread Number: 85774  /  Tag: Modern Automatic Washers
Another one saved!
Post# 1103254   1/5/2021 at 11:42 (1,197 days old) by MaytagNeptune (FireAlarmTechGuy4444 on YouTube. Interlochen MI)
maytagneptune's profile picture
I went to the used appliance store yesterday and found this LG Front loader on the scrap crate. It was in the back but I pulled it all the way to the front. I decoded the serial number and saw it was made in South Korea in July of 2012. This is a Entry Level model. The power cord was cut so I jumpered it and tested it. The only problem is the pump was clogged. I unclogged it. Now it needs a ton of work. I almost passed this one over. The door boot is NASTY! There is mold completely covering it. I'm gonna vomit! It's so GROSS! This machine does not have the sealed tub. The bearings,Spider and seal are still good. so is the Motor Controller Board and the Hall sensor. Once I clean it I will test it. if I can fix it for cheap I will replace the cord and it will be available for sale for $185.
Post# 1103312 , Reply# 1   1/5/2021 at 21:46 (1,196 days old) by Pierreandreply4 (St-Bruno de montarville (province of quebec) canada)
congratulation
congratulation and hope that this washer will find a nice home and be well taken care of
Post# 1103378 , Reply# 2   1/6/2021 at 09:50 (1,196 days old) by vacerator (Macomb, Michigan)
Is it LG,
Samsung, or Frigidaire Affiniyt?
Post# 1103385 , Reply# 3   1/6/2021 at 10:46 (1,196 days old) by combo52 (50 Year Repair Tech Beltsville,Md)
Good Save ??
combo52's profile picture
Hi Kelly, how can you tell the spider is in good shape, have you dissembled the outer tub ?
Often gross smelly machines this age the spider is not in good shape.
John L.
Post# 1104431 , Reply# 4   1/13/2021 at 15:43 (1,189 days old) by MaytagNeptune (FireAlarmTechGuy4444 on YouTube. Interlochen MI)
wamp wamp wamp waaaaaaaaaaaaamp
This is a fail. I parted it out. it was too nasty and the spider was broken in 2 spots.
Post# 1104606 , Reply# 5   1/15/2021 at 09:50 (1,187 days old) by vacerator (Macomb, Michigan)
Too bad Kelly!
spider corrosion is common. It could have been replaced. Do you know the manufacturer of it?
