Thread Number: 85786
/ Tag: Vintage Dryers
Cause I’m a crafty bitch. DE806 |
Post# 1103309   1/5/2021 at 21:00 (1,198 days old) by Elginkid (Cincinnati, OH)   |   | |
So...the felt seal on the Halo of Heat is NLA, and the only ones out there are $35-$38. At an inch wide, that makes the felt over $1200 a yard. I think not. I went to Michael’s, found some coordinating 100% Wool Felt and felting needles and made my own. If Volvoguy87 can find the high heat glue, it’s getting installed tonight. $15 in materials and enough to make 4 seals.
Post# 1103323 , Reply# 1   1/5/2021 at 22:18 (1,197 days old) by Maytag85 (Sean A806)   |   | |
One trick I did with my avocado DG606 that was converted to a DG306 is I used a long piece of felt weather stripping to help make a good seal around the heating shroud and use a big paper clip to hold it together and so far it’s held up since 2019 and it’s that piece of felt that would otherwise be glued to retain a little tension on the 3” felt seal that helps direct the air through the burner and air mixer assembly.
