Thread Number: 85860
Whirlpool DD failure what do you think could be wrong? |
Post# 1104156 , Reply# 1   1/11/2021 at 16:27 (1,194 days old) by Repairguy (Danbury, Texas)   |   | |
Post# 1104163 , Reply# 2   1/11/2021 at 17:13 (1,194 days old) by DADoES (TX, U.S. of A.)   |   | |
Presumably there's no temperature difference between the Warm and Hot fill ... cold water obstructed so warm is only hot flowing. There may be debris screens both in the inlet valve ports and at the faucet-ends of the hoses. Check both. Be careful trying to pull the screens in the valve if they're metal/mesh. Puncturing/deforming the mesh will allow future debris into the valve. |
Post# 1104169 , Reply# 3   1/11/2021 at 17:39 (1,194 days old) by Maytag85 (Sean A806)   |   | |
The water inlet valve definitely seems to be acting up. Had to end up doing a partial rebuild to the inlet valve on my ‘63 Whirlpool since water was trickling into the tub even when the machine was off and someone removed the mesh screens at some point when the machine was repaired 20 years ago or so.
Post# 1104184 , Reply# 5   1/11/2021 at 18:41 (1,194 days old) by Repairguy (Danbury, Texas)   |   | |
Post# 1104194 , Reply# 6   1/11/2021 at 19:18 (1,194 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 1104220 , Reply# 7   1/11/2021 at 21:27 (1,194 days old) by GusHerb (Chicago/NWI)   |   | |
It turns out it has those flood safe hoses on it. That could be the culprit too. They’re gonna remove them and check the screen and check flow.
Post# 1104222 , Reply# 8   1/11/2021 at 21:31 (1,194 days old) by GusHerb (Chicago/NWI)   |   | |
There it is going into final spin. Sounds perfectly healthy to me. |
Post# 1104225 , Reply# 9   1/11/2021 at 21:44 (1,194 days old) by Pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
did you check to see if it fills on rinse with only hot water or check if its not that part that might need to be replace or clog? and including link to part number
CLICK HERE TO GO TO Pierreandreply4's LINK
Post# 1104227 , Reply# 10   1/11/2021 at 21:54 (1,194 days old) by maytag142c (Syracuse NY)   |   | |
If it needs a set of valves which it sounds like it might, I have a few. Send me a message if you'd like. |
Post# 1104442 , Reply# 11   1/13/2021 at 18:36 (1,192 days old) by GusHerb (Chicago/NWI)   |   | |
It's all fixed. The Flood Safe hoses were the culprit. |
Post# 1104446 , Reply# 12   1/13/2021 at 19:00 (1,192 days old) by Repairguy (Danbury, Texas)   |   | |
