Thread Number: 85982
Electrolux WH 3335 Caught Fire Scary story |
Post# 1105380 , Reply# 1   1/21/2021 at 12:19 (1,189 days old) by Tomturbomatic (Beltsville, MD)   |   | |
I'm sorry for the fright and the loss. Hope you and the house are OK. When you turned it over did water run out? Did you get the clothes out OK? |
Post# 1105400 , Reply# 2   1/21/2021 at 14:20 (1,189 days old) by Hippiedoll ( arizona )   |   | |
Post# 1105434 , Reply# 3   1/21/2021 at 19:43 (1,188 days old) by tnmike (Knoxville, Tennessee)   |   | |
Post# 1105465 , Reply# 5   1/21/2021 at 23:28 (1,188 days old) by turbokinetic (Northport, Alabama USA)   |   | |
Sorry you had to deal with that smoky mess and scary incident!
Did you look inside the cabinet? What actually burned in there? |
Post# 1105479 , Reply# 7   1/22/2021 at 05:39 (1,188 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Oh, that's awful! Glad it didn't end up worse.
Is this a similar model?
Post# 1105485 , Reply# 9   1/22/2021 at 07:02 (1,188 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Sorry about the mess, you should contact Electrolux for sure as they would at least give you a new washer.
This is why I do not like machines that use a lot of plastic for the frames etc, A lot of LG and SS washers use plastic frames around the bottom and along with a plastic outer tub you can have a real mess when thing go wrong.
Most smaller non US washer and dryers do not even have a steel top and when things go wrong there have been some serious fires.
This is one of the many things I like about my new SQ FL washer is that there is almost no plastic used inside the machine. and it is completely encased in metal including the bottom.
