Thread Number: 86056
TR5 Tub Shaft Bolt torque spec |
Post# 1106391 , Reply# 1   1/31/2021 at 17:25 (1,179 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Hi Keith, SQ sugests lighting the 1 1/2" nut to 700-1000 inches torque, I would also add some lock-tight to the nut threads.
You can either do this through the opening in the base pan or remove the motor and use a wrench with a pipe extension.
If you call SQ you can probably get them to send you a new belt while you are at it to see if that stops the belt sound.
