Thread Number: 86130
Speed Queen TC5 Revised Cycle Matrix |
Post# 1142839 , Reply# 1   2/22/2022 at 16:20 (792 days old) by Jben (AL)   |   | |
For the water use (gallons) in the two right side wash columns; is that for the complete wash cycle (i.e. the wash and a rinse) or is that just for the wash and each rinse would use a similar amount ? |
Post# 1142840 , Reply# 2   2/22/2022 at 16:32 (792 days old) by appnut (TX)   |   | |
Post# 1142849 , Reply# 3   2/22/2022 at 17:14 (792 days old) by DADoES (TX, U.S. of A.)   |   | |
The lowest water usage possible on the TC5 via the Normal Eco cycle with no options (which does spin-spray rinses instead of a filled/agitated rinse) is 13 gals + the rinse sprays. Adding an Extra Rinse to it includes the spin-sprays and a filled/agitated rinse which ups it another 13 gals to 26+ gals total. Does Heavy Soil option also add the agitated rinse to Normal Eco, and give two agitated rinses on the other cycles? The setting isn't labeled as such and the user guide doesn't clarify that point. Maximum is 57 gals (+ sprays if any) for all of the other cycles with Deep Fill and Extra Rinse selected. Appears that a full cycle of wash/soak with agitated rinse can be had by selecting Spin and the Extra Rinse Pre-Soak option. An agitated rinse and spin via Spin and Extra Rinse. |
