Thread Number: 86179
/ Tag: Vintage Dishwashers
Kitchenaid KDS17A |
Post# 1107391 , Reply# 1   2/9/2021 at 18:05 (1,170 days old) by Steved (Guilderland, New York)   |   | |
I bet the drain valve is stuck open with a toothpick, or bread twister. So water is running in and right out. The experts here can confirm |
Post# 1107413 , Reply# 2   2/9/2021 at 21:04 (1,170 days old) by coreycwc (Eastland, Texas )   |   | |
Definitely hoping one of the experts here can offer some insight. Fingers crossed! |
Post# 1107547 , Reply# 3   2/11/2021 at 06:28 (1,169 days old) by chachp (North Little Rock, AR)   |   | |
Here are a couple of screen shots of how to remove your drain valve. It's pretty easy to remove and you can check it out to see if it it stuck open. You can also test to see if it's working correctly. |
