Thread Number: 86226
/ Tag: Modern Dishwashers
KA dw without a Sensor cycle |
Post# 1107702   2/12/2021 at 08:50 (1,161 days old) by PeterH770 (Marietta, GA)   |   | |
Post# 1107703 , Reply# 1   2/12/2021 at 08:57 (1,161 days old) by PeterH770 (Marietta, GA)   |   | |
Post# 1107706 , Reply# 2   2/12/2021 at 09:21 (1,161 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1107994 , Reply# 3   2/14/2021 at 20:44 (1,159 days old) by peterh770 (Marietta, GA)   |   | |
Post# 1108028 , Reply# 5   2/15/2021 at 06:23 (1,159 days old) by henene4 (Heidenheim a.d. Brenz (Germany))   |   | |
From the manual it appears all 3 cycles (Heavy, Normal, Light) have different runtimes and water usage depending on soiling (and load, for that matter). So it will probably change the number of prewashes and rinses... |
Post# 1108105 , Reply# 6   2/15/2021 at 18:48 (1,158 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 1108402 , Reply# 7   2/17/2021 at 16:21 (1,156 days old) by peterh770 (Marietta, GA)   |   | |
Post# 1108406 , Reply# 8   2/17/2021 at 16:40 (1,156 days old) by appnut (TX)   |   | |
Peter, I can tell you on my 2006 Kenmore Elite (KitchenAid), if no purge was required most times it didn't exchange water after prewash, but went into main wash. Heavier soil caused a purge in prewash as well as check for another purge in main wash. The number would impact main wash temperature/length and also whether there was a post-wash purge or full rinse. Heavy also automatically did two full post wash rinses. Light/China had a lower main wash temperature set point as well as final rinse. And only did a post wash purge and final rinse.
