Thread Number: 86251
Fle3000 issue |
Post# 1108249 , Reply# 1   2/16/2021 at 15:59 (1,135 days old) by reversomatic (east anglia,england,u.k.)   |   | |
Hi , it could be due to the temperature of the incoming cold water . Has this error only started with the colder weather. I remember long ago when i used to work on this model range reading a technical bulletin , it stated that if the incoming cold water temperature was very low the ntc temperature sensor would read this as an error. It could tie in with when the machine is loading in more and more cold water for the rinsing. I guess they were designed with Italian water temperatures in mind. Just a thought. Nigel.
Post# 1129488 , Reply# 2   9/24/2021 at 08:48 (916 days old) by fle3000 (Herne bay kent )   |   | |
hello sorry for the long delay i am still having issues with the fle3000 giving me the 1a error code its now starting to do it whiles its filling up i really dont under stand it can any one help |
Post# 1130031 , Reply# 5   9/30/2021 at 17:55 (909 days old) by Rolls_rapide (.)   |   | |
Did you swap the FLE3000's heater for the other heater? What model was the donor machine? |
Post# 1130057 , Reply# 6   10/1/2021 at 01:48 (909 days old) by fle3000 (Herne bay kent )   |   | |
hi it was a fl1024 we didnt swap the heaters as the donor one was new and of same type am thinking the hearter relay needs cleaning after all these yeahs with contact cleaner the motor for the fle3000 is a brand new one |
Post# 1130122 , Reply# 8   10/1/2021 at 18:34 (908 days old) by Rolls_rapide (.)   |   | |
Also, check the wiring between the thermistor and the PCB, look out for corrosion at connectors, or broken wires. |
