Thread Number: 86379
/ Tag: Vintage Dishwashers
Noisy KitchenAid Superba KUDS22 |
Post# 1109654   2/26/2021 at 20:04 (1,147 days old) by Superwash (Cape Coral, FL)   |   | |
So the Superba has been fine until last night when this noise started.
Sounds like the impeller to the pump is bad. Is this a pump replacement? I know the pumps are no longer made, right? I hate to ditch this machine to buy a new dishwasher. CLICK HERE TO GO TO Superwash's LINK |
Post# 1109665 , Reply# 1   2/26/2021 at 20:57 (1,147 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 1109667 , Reply# 2   2/26/2021 at 21:33 (1,147 days old) by Superwash (Cape Coral, FL)   |   | |
Post# 1109687 , Reply# 3   2/27/2021 at 06:30 (1,146 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
I would check for the loose fan first, you can do that with your finger without removing any parts.
If the fan is loose on the motor shaft yo will need to remove the entire pump and motor and either replace the motor assembly or you may be able to epoxy the fan blade on the motor shaft after you completely have removed the assembly and dissembled it.
If the fan is still attached to the motor shaft you can dissemble the pump while it is still installed in the DW and look for foreign objects or broken wash pump impeller etc.
Post# 1109716 , Reply# 4   2/27/2021 at 11:35 (1,146 days old) by Superba1 (CA)   |   | |
I have the pump from my kuda22st if you need it. |
Post# 1109718 , Reply# 5   2/27/2021 at 11:51 (1,146 days old) by Superwash (Cape Coral, FL)   |   | |
Post# 1109733 , Reply# 6   2/27/2021 at 16:13 (1,146 days old) by Superwash (Cape Coral, FL)   |   | |
No foreign materials in the pump assembly whatsoever.
However the seal for the drain pump is completely deteriorated. I was trying to find one online, but seems they are no longer available.
Post# 1109745 , Reply# 7   2/27/2021 at 18:42 (1,146 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 1109803 , Reply# 8   2/28/2021 at 11:44 (1,145 days old) by Superwash (Cape Coral, FL)   |   | |
Post# 1109888 , Reply# 9   3/1/2021 at 10:46 (1,144 days old) by Superwash (Cape Coral, FL)   |   | |
John,
Update 3/1/21 Looks like it IS the cooling fan blade on the motor. Initially, I was unsuccessful finding the gaskets needed on eBay. However I refined the search to "Whirlpool with part number" and "FSP and part number". And wouldn't you know it? I found the motor mount gasket! I still need a drain pump gasket. No luck on eBay, but I did find it as "special order" on the Coastal Parts site in CA. I will call them this morning to make sure that they can order this part. |
Post# 1109903 , Reply# 10   3/1/2021 at 11:40 (1,144 days old) by Superwash (Cape Coral, FL)   |   | |
