Thread Number: 86430
/ Tag: Vintage Dryers
'61 Kenmore dryer lubrication |
Post# 1110115 , Reply# 1   3/3/2021 at 17:34 (1,121 days old) by Maytag85 (Sean A806)   |   | |
Post# 1110218 , Reply# 2   3/4/2021 at 17:59 (1,120 days old) by LadyK (Tacoma)   |   | |
Post# 1110222 , Reply# 3   3/4/2021 at 19:41 (1,120 days old) by Maytag85 (Sean A806)   |   | |
Post# 1110247 , Reply# 4   3/4/2021 at 22:47 (1,120 days old) by Kenmoreman ( Southern NH)   |   | |
If you take the blower assembly out and separate the plates you will find the oil wick. You can pop the clip off and saturate the wick and replace the clip. Much more effective. |
Post# 1110273 , Reply# 6   3/5/2021 at 08:04 (1,119 days old) by swestoyz (Cedar Falls, IA)   |   | |
Not sure of the material used on the Kenmore/Whirlpool bearing, but Paul got some great advice to rehab the bearing on a '59 Frigidaire. Looks like GM used a bronze bearing.
If you're working with a softer metal bearing on your Kenmore that was "lubricated for life", maybe give this a try? www.automaticwasher.org/c... Ben |
