Thread Number: 86606
/ Tag: Vintage Dishwashers
Halo of heat dryer |
Post# 1112047   3/19/2021 at 13:47 (1,133 days old) by gage164 (new york)   |   | |
1970 De406 not drying clothes on permanent press cycle need to run 2 or more cycles |
Post# 1112054 , Reply# 1   3/19/2021 at 14:57 (1,133 days old) by Maytag85 (Sean A806)   |   | |
Post# 1112065 , Reply# 2   3/19/2021 at 17:15 (1,132 days old) by gage164 (new york)   |   | |
It takes 2 or 3 cycles on permanent press the reg cycle seems ok |
Post# 1112067 , Reply# 3   3/19/2021 at 17:25 (1,132 days old) by appnut (TX)   |   | |
Post# 1112071 , Reply# 4   3/19/2021 at 17:48 (1,132 days old) by gage164 (new york)   |   | |
Do you know if you can still get the hi limit stat and where is it located? Do you happen to know the temperature s for the reg cycle and perm cycle? Thank you for any information and help you can provide |
Post# 1112085 , Reply# 5   3/19/2021 at 19:12 (1,132 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
If it works on regular just use regular, the only difference is regular has a 3 minute cool Down and PP has like 7 minutes.
There is only one operating thermostat on this dryer, both cycles have the same temperature, if it really does not work on PP you have a bad heat contact in the timer and you need another timer.
