Thread Number: 86616
Maytag washer A710 series 1 |
Post# 1112180   3/21/2021 at 05:35 (1,104 days old) by gage164 (new york)   |   | |
My washer is starting to make a grinding type of noise in the drain and spin cycles,any suggestions on what to check? |
Post# 1112219 , Reply# 1   3/21/2021 at 14:03 (1,103 days old) by RP2813 (Sannazay)   |   | |
Post# 1112233 , Reply# 2   3/21/2021 at 15:23 (1,103 days old) by gage164 (new york)   |   | |
Pump seems to work fine started spinning made noise motor cut out waited 15 minutes or so everything came back on still made noise when spinning |
Post# 1112241 , Reply# 3   3/21/2021 at 17:01 (1,103 days old) by Good-Shepherd (New Jersey)   |   | |
Tub bearing seizing up or something is binding the tub since the motor overheated. "Grinding" sounds like metal on metal hence the suspected tub bearing. |
Post# 1112262 , Reply# 4   3/21/2021 at 19:20 (1,103 days old) by gage164 (new york)   |   | |
Thank you ,do you know if these parts are still available? |
Post# 1112299 , Reply# 6   3/22/2021 at 02:53 (1,103 days old) by gage164 (new york)   |   | |
I will check other things as you suggested, there is no set screw on my agitator how do you remove that from the shaft? What other problems should I look for first . Thank you |
Post# 1112384 , Reply# 8   3/22/2021 at 17:15 (1,102 days old) by gage164 (new york)   |   | |
Ok I will try and figure it out thank you again |
