Thread Number: 86709
Whirlpool A308 Tub Leak? |
Post# 1112918 , Reply# 1   3/27/2021 at 20:14 (1,122 days old) by RP2813 (Sannazay)   |   | |
Post# 1112929 , Reply# 2   3/27/2021 at 22:38 (1,122 days old) by nuwash (Fort Wayne, IN)   |   | |
Lol, yes Maytag! (Facepalm) Thanks for catching that! |
Post# 1112935 , Reply# 3   3/27/2021 at 23:18 (1,122 days old) by LowEfficiency (Iowa)   |   | |
The seal/gasket is indeed replaceable. Look for part number 2-11232, 211232, or WP211232.
But from the looks of things, your machine has been spilling over the top of the tub for quite some time. Before removing that seal, it might be good to check that it isn't over-filling. It also would be a good idea to clean and scrub that upper tub cover, as there are drain holes that should direct splashes back into the tub, which are probably clogged. |
Post# 1113100 , Reply# 4   3/29/2021 at 08:40 (1,120 days old) by nuwash (Fort Wayne, IN)   |   | |
Thank you for the info! I had suspected overfilling so I did open the top up and clean out the drain holes. They were indeed plugged. What would cause overfilling? The settings to control the fill seem to be working fine. |
Post# 1113107 , Reply# 5   3/29/2021 at 10:42 (1,120 days old) by nuwash (Fort Wayne, IN)   |   | |
I apologize for the bad picture! I meant to point out that the tub has been cleaned and looks a lot better now! |
Post# 1113147 , Reply# 6   3/29/2021 at 17:31 (1,120 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 1113158 , Reply# 7   3/29/2021 at 19:09 (1,120 days old) by LowEfficiency (Iowa)   |   | |
