Thread Number: 86750
Single speed kenmore? |
Post# 1113229   3/30/2021 at 15:39 (1,093 days old) by Cam2s (Nebraska)   |   | |
Was this a single speed model? |
Post# 1113231 , Reply# 1   3/30/2021 at 15:49 (1,093 days old) by appnut (TX)   |   | |
Post# 1113236 , Reply# 2   3/30/2021 at 16:19 (1,093 days old) by Repairguy (Danbury, Texas)   |   | |
Post# 1113277 , Reply# 3   3/30/2021 at 23:36 (1,093 days old) by whirlykenmore78 (Prior Lake MN (GMT-0500 CDT.))   |   | |
Post# 1113307 , Reply# 4   3/31/2021 at 07:09 (1,093 days old) by Tomturbomatic (Beltsville, MD)   |   | |
The speeds are built into the cycles on the timer. |
Post# 1113332 , Reply# 6   3/31/2021 at 09:33 (1,093 days old) by appnut (TX)   |   | |
Post# 1113404 , Reply# 7   3/31/2021 at 19:36 (1,092 days old) by Yogitunes (New Jersey)   |   | |
when the first ones came out, most were single speed, and usually 1 or 2 cycles....but the one speed showed issues of clothing damage...
in later years, the "Normal" cycle changed to a lower speed agitation....note this machine has a Normal cycle, with Gentle/Knits incorporated into this portion... as well as a Heavy Duty cycle for high speed across the board... |
Post# 1113418 , Reply# 8   4/1/2021 at 03:28 (1,092 days old) by toploadloyalist (San Luis Obispo, CA)   |   | |
Around the start of the 60s, single-speed washers started having a SHORT cycle for delicates, alongside a NORMAL one. Starting c.1980, single-speeders had a PERMANENT PRESS I, while two-speeders had later had PERMANENT PRESS II. |
