Thread Number: 86888
LG WashTower |
Post# 1114604   4/14/2021 at 08:28 (1,101 days old) by kakidd (Texas)   |   | |
Does anyone have the new LG WashTower? If so, I'm curious to know if you like it and if you would recommend purchasing? |
Post# 1114615 , Reply# 1   4/14/2021 at 10:40 (1,101 days old) by appnut (TX)   |   | |
Post# 1114616 , Reply# 2   4/14/2021 at 10:40 (1,101 days old) by Frigilux (The Minnesota Prairie)   |   | |
Here's a photo.
Post# 1114618 , Reply# 3   4/14/2021 at 10:44 (1,101 days old) by appnut (TX)   |   | |
Post# 1114628 , Reply# 4   4/14/2021 at 12:44 (1,101 days old) by kakidd (Texas)   |   | |
This is great information, I appreciate your input! |
Post# 1114664 , Reply# 7   4/14/2021 at 21:39 (1,101 days old) by lakewebsterkid (Dayton, Ohio)   |   | |
I have used one. It is very quick using the Normal cycle, but does only one rinse. I don't care for the lack of cycles, but it has all the major pros of an LG machine. Very quiet, quick, good cleaning, and fairly reliable. |
Post# 1114666 , Reply# 8   4/14/2021 at 21:50 (1,101 days old) by appnut (TX)   |   | |
Post# 1114671 , Reply# 9   4/14/2021 at 22:52 (1,101 days old) by powerfin64 (Yakima, Washington)   |   | |
Post# 1114679 , Reply# 11   4/15/2021 at 00:58 (1,100 days old) by appnut (TX)   |   | |
Rich, the cycles that are on the control panel are Normal, Bedding, Heavy Duty, Delicates, and Sanitary. Permanent Press, Towels, Whitest Whites, and Allergene cycles found on most other LG's as part of default cycles is only available via the downloaded app.
Glad to see you posting again starting last year after a long break. Send me an email so we can catch up with each other. |
Post# 1114692 , Reply# 12   4/15/2021 at 09:19 (1,100 days old) by powerfin64 (Yakima, Washington)   |   | |
Post# 1114693 , Reply# 13   4/15/2021 at 09:36 (1,100 days old) by Golittlesport (California)   |   | |
LG washers with Turbo Wash provide two spin spray rinses along with the one deep rinse that is default on the "normal" cycle. As others have pointed out, you can add up to three more deep rinses to that cycle if you like. (That's four deep rinses with a spin spray between each one.)
Using the default Normal cycle (one deep rinse) on a light soil setting will give you a speed wash cycle. |
Post# 1114694 , Reply# 14   4/15/2021 at 09:37 (1,100 days old) by henene4 (Heidenheim a.d. Brenz (Germany))   |   | |
As far as I understand, TurboWash is the default on Normal. Without TurboWash it should 2 normal bath rinses with low level. TurboWash by default does 1 spray rinse and 1 pretty deep rinse plus a spray during the final spin. Each added rinses adds 1 spray and 1 deep rinse. |
Post# 1114728 , Reply# 16   4/15/2021 at 15:35 (1,100 days old) by lakewebsterkid (Dayton, Ohio)   |   | |
Actually, on the WashTower I used, TurboWash can not be deactivated on the Normal cycle. If I recall correctly, it can not be deactivated in a majority of the newer machines, including the WashTowers. |
Post# 1114734 , Reply# 17   4/15/2021 at 18:16 (1,100 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
How much time estimated does the normal cycle last on the dryer? |
Post# 1114739 , Reply# 18   4/15/2021 at 19:04 (1,100 days old) by appnut (TX)   |   | |
Post# 1114755 , Reply# 19   4/15/2021 at 23:53 (1,099 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
How long is the normal cycle without energy saver? |
Post# 1114778 , Reply# 20   4/16/2021 at 12:25 (1,099 days old) by Golittlesport (California)   |   | |
With my LG 3570 model, my go-to cycle for most loads is normal (turbo wash) with normal soil and one added rinse. I typically choose hot water which delivers 95 - 100 degree wash water, which I consider warm. That gives three spin spray rinses and two deep rinses. Cycle time runs between 38 - 45 minutes depending on the weight of the load it senses.
I should create a "favorite" cycle with this combination, but have not ever bothered. |
Post# 1114789 , Reply# 21   4/16/2021 at 13:58 (1,099 days old) by Logixx (Germany)   |   | |
Several years ago, LG had a dryer with AdaptAble controls, which meant the control panel could be mounted on the bottom of the dryer. Now Samsung have front loaders with a washer|dryer button, so the washer can control the dryer on top.
