Thread Number: 87199
Photos please. |
Post# 1117745   5/20/2021 at 06:39 (1,065 days old) by chachp (North Little Rock, AR)   |   | |
I am trying to convince a friend to stop doing all cold water washes. I am trying to find a good photo of what it does to your washing machine over time and no matter how I search here I'm not finding a good one. Can someone send me a good example? I want to shock her into using hot water once in a while. LOL.
Thank you. I know I'll get some good ones. |
Post# 1117746 , Reply# 1   5/20/2021 at 06:46 (1,065 days old) by Pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
this is from my g1 duet washer do not know if it will help thanks to this site i have been using warm and hot water wash more than cold
Post# 1117747 , Reply# 2   5/20/2021 at 06:50 (1,065 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
All cold water and too little detergent, keep in mind you can wash quite well in cold water if you use enough detergent for the water temperature and hardness and soil level.
These pictures are from a service call yesterday, the washer stoped running and was flashing a full code.
All the socks etc had fallen over the tub cover from careless use [ and bad washer design ] that allows things to fall over when loading and unloading.
A pair of Victoria's Secret panties got wrapped in the motors cooling fan and ripped the speed sensor of the motor, luckily I was able to remove the motor and reinstall the sensor and get it running without any expensive parts. The main bearings on this 5YO machine already sound like a freight train when this washer is spinning.
John |
Post# 1117748 , Reply# 3   5/20/2021 at 06:51 (1,065 days old) by chachp (North Little Rock, AR)   |   | |
Post# 1117769 , Reply# 4   5/20/2021 at 09:21 (1,065 days old) by Pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
i am no expert but i can say with today washers compared to vintage machines the problem is atc temp control that mix hot and cold water makes warm water more like cool water than warm same for hot water that more like warmwater since base on normal cycle on modern washers of today cools down water unless washer has an internal heater to keep water at actual wash temp pic is an exemple of a washer with true wash rinse temp no atc control
Post# 1117777 , Reply# 5   5/20/2021 at 10:14 (1,065 days old) by JohnBee (USA, NY)   |   | |
Post# 1117784 , Reply# 6   5/20/2021 at 11:08 (1,065 days old) by DADoES (TX, U.S. of A.)   |   | |
Several toploaders, mostly WP/KM DDs. #14 is an (at the time) 11-yo Norgetag that belonged to my aunt. She has better habits and they added a water softener to the house at some point of owning it. |
Post# 1117794 , Reply# 7   5/20/2021 at 12:06 (1,065 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
What brand of washer did you work on that had this issue? |
Post# 1117851 , Reply# 8   5/20/2021 at 21:23 (1,064 days old) by Tomdawg (Des moines)   |   | |
Cold water washing.. the main area might look clean, but the inside is nasty and it stinks! |
Post# 1117857 , Reply# 9   5/20/2021 at 22:38 (1,064 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
is when I wash a load of darks. |
Post# 1117880 , Reply# 10   5/21/2021 at 06:09 (1,064 days old) by ozzie908 (Lincoln UK)   |   | |
Whats the point of saving a few pennies on hot water when you have to send the washer to landfill way before its time?
The thought of using cold water to wash underwear etc makes me want to vomit. I think the lowest temperature I have ever used is 30c can't recall what I was washing but no doubt it said cold on the label.... To avoid shrinkage just buy the next size up or get pre-shrunk clothing. Eww to nasty washing machines and smelly clothes may as well bash them on a rock by a river. Austin |
Post# 1117888 , Reply# 12   5/21/2021 at 11:07 (1,064 days old) by DADoES (TX, U.S. of A.)   |   | |
Pierre, What's going in the area between the arrows? Mold? Presumably the boot isn't torn there or you'd have leaking.
Post# 1117889 , Reply# 13   5/21/2021 at 11:13 (1,064 days old) by swestoyz (Cedar Falls, IA)   |   | |
F&P IWL12 from 2004, shot taken this past September after I bought the machine.
While I did clean the washer in the basement my wife complained of the stench up in the kitchen. The most fowl smelling washer I have yet to clean. Before/After |
Post# 1117895 , Reply# 15   5/21/2021 at 11:38 (1,064 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1117906 , Reply# 17   5/21/2021 at 15:27 (1,064 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1117907 , Reply# 18   5/21/2021 at 15:31 (1,064 days old) by Egress (Oregon)   |   | |
wow, thats quite a bit longer. wonder how well it cleans compared to other manufacturers cycles |
Post# 1117910 , Reply# 19   5/21/2021 at 16:04 (1,064 days old) by Pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
