Thread Number: 87273
Patent of the Day |
Post# 1118564   5/28/2021 at 08:43 (1,062 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1118567 , Reply# 1   5/28/2021 at 10:12 (1,062 days old) by eronie (Flushing Michigan)   |   | |
I look every day, but it seems that most of them are from the Whirlpool corporation. |
Post# 1118569 , Reply# 2   5/28/2021 at 10:37 (1,062 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1118866 , Reply# 3   5/31/2021 at 09:55 (1,059 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1118950 , Reply# 4   6/1/2021 at 07:58 (1,058 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1119028 , Reply# 5   6/2/2021 at 08:14 (1,057 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1119228 , Reply# 6   6/4/2021 at 05:26 (1,055 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1119667 , Reply# 7   6/8/2021 at 08:37 (1,051 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1120536 , Reply# 8   6/17/2021 at 08:22 (1,042 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1122011 , Reply# 9   7/1/2021 at 09:36 (1,028 days old) by DADoES (TX, U.S. of A.)   |   | |
Thu 07/01/2021 -- General Motors / Frigidaire dated 10/19/1943 for a direct-drive, reversing-motor washing machine mechanism with "thimble-shaped agitator" which rotates at motor speed with a helical vane on the centerpost that churns the water for washing and rinsing, and a brake-and-clutch which allows rotating the tub for extraction. |
Post# 1122301 , Reply# 10   7/4/2021 at 09:36 (1,025 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1122305 , Reply# 11   7/4/2021 at 10:58 (1,025 days old) by agiflow ()   |   | |
...and here we are today with the vmw design today. |
Post# 1125253 , Reply# 12   8/7/2021 at 09:28 (991 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1129490 , Reply# 13   9/24/2021 at 10:14 (943 days old) by DADoES (TX, U.S. of A.)   |   | |
Fri 9/24/2021 -- Dated 3/6/1956, topload washer with a separate/integral water heating reservoir to preheat water for a rinse following the wash period, or for washing the next load, and a solid oscillating/spinning tub with integral ramped agitation hub. Hot rinse is touted as necessary to handle removal of soil and detergent/soap scum from fabric fibers, which contract in cold water. Solid spin tubs are touted as superior for sanitization by way of eliminating the space between an outer tub and inner basket or lining which is an inaccessible cavity where germs, bacteria, and fungi can breed. So, yeah, it was known 65 years ago that washers can get gnasty. |
Post# 1129491 , Reply# 14   9/24/2021 at 11:00 (943 days old) by Unimatic1140 (Minneapolis)   |   | |
This looks like a very cool washer! Too bad it was never made. From the patent text:
It is definitely known that hot water expands the fibers in clothes, cold water contracts the same, thereby the dirt and detergent cling to the meshes of the fibers, causing gray colored clothes when rinsing in cold water. This condition is evidenced by the fact that present day automatic washing machines are using several spray rinses in an attempt to clear the clothes of dirt and detergents. Furthermore, many of the automatic washing machines now on the market are provided with a perforated liner arranged in spaced relation from the main body of the tub, so as to provide a cavity between the wall of the tub and the liner for the circulation of the water. This has been found necessary with some constructions in order to obtain adequate water circulation, at the expense of sanitation, in that the cavity between the liner and the main body of the tub provides an inaccessible breeding place for germs, bacteria and fungi. This is one of the reasons I love my solid-tub washers, there is no way for anything that is in the outer tub to contact the items being washed. The exception to this is the solid-tub GE Filter-Flo's, but the water level is only right at the bottom of the outer tub for recirculation so it's reach is less to a certain extent than perforated tub washers. |
Post# 1129553 , Reply# 15   9/25/2021 at 07:21 (942 days old) by agiflow ()   |   | |
Yeah but won't hot washes, bleach and enough detergent circumvent that from happening ? It's nice to have a machine that can do warm rinses. |
Post# 1129555 , Reply# 16   9/25/2021 at 08:08 (942 days old) by Paulg (My sweet home... Chicago)   |   | |
Here it is. A copy is framed in my laundry room along with a picture of Joy who I used to work with.
Dan Stelli, who with my Dad made the patent possible, passed away in 1970 at age 51. |
Post# 1129562 , Reply# 17   9/25/2021 at 10:47 (942 days old) by Repairguy (Danbury, Texas)   |   | |
Post# 1129570 , Reply# 18   9/25/2021 at 12:39 (942 days old) by Paulg (My sweet home... Chicago)   |   | |
Post# 1129590 , Reply# 19   9/25/2021 at 16:59 (942 days old) by Repairguy (Danbury, Texas)   |   | |
Post# 1129985 , Reply# 20   9/30/2021 at 10:14 (937 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1130601 , Reply# 21   10/7/2021 at 07:41 (930 days old) by chachp (North Little Rock, AR)   |   | |
The main issue I have with using it is I never seem to see the posts until the next day when its moved on to something else. I understand they are random but I wonder if there is or has been any consideration to setting it up with some kind of history, so we could plug in a date and see what was listed on that date.
Or is it an option to give us a button we could click in the message to fill in the URL to that day's POTD so if we're looking at it on a different day we could use the URL to get to the one that is referred to in the message. Maybe something like click this button to fill in the URL to today's POTD? |
Post# 1131106 , Reply# 22   10/14/2021 at 09:51 (923 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1131115 , Reply# 23   10/14/2021 at 13:12 (923 days old) by coldspot66 (Plymouth, Mass)   |   | |
Very interesting. I wonder if a prototype was built or if this ever happened. I wonder if it was based on the belt drive design/cabinet. |
Post# 1131293 , Reply# 24   10/17/2021 at 09:34 (920 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1133222 , Reply# 25   11/11/2021 at 08:41 (895 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1134124 , Reply# 26   11/21/2021 at 09:25 (885 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1134125 , Reply# 27   11/21/2021 at 09:50 (885 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 1136524 , Reply# 28   12/18/2021 at 09:44 (858 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1136529 , Reply# 29   12/18/2021 at 10:34 (858 days old) by Golittlesport (California)   |   | |
Post# 1138727 , Reply# 30   1/8/2022 at 10:17 (837 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1139182 , Reply# 31   1/13/2022 at 07:07 (832 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1139184 , Reply# 32   1/13/2022 at 07:43 (832 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Post# 1139591 , Reply# 33   1/17/2022 at 09:09 (828 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1139598 , Reply# 34   1/17/2022 at 10:33 (828 days old) by Adam-aussie-vac (Canberra ACT)   |   | |
An extra tall dishwasher for hanging laundry? |
Post# 1141494 , Reply# 35   2/7/2022 at 07:34 (807 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1141812 , Reply# 36   2/10/2022 at 08:23 (804 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1141958 , Reply# 37   2/12/2022 at 08:44 (802 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1142052 , Reply# 38   2/13/2022 at 10:11 (801 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1143177 , Reply# 39   2/26/2022 at 10:38 (788 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1146927 , Reply# 40   4/19/2022 at 07:42 (736 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1148302 , Reply# 41   5/8/2022 at 11:06 (717 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1150847 , Reply# 42   6/11/2022 at 09:17 (683 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1150947 , Reply# 43   6/12/2022 at 18:52 (682 days old) by UltraWash (Charlotte, North Carolina )   |   | |
So it was almost like the Calypso? Was there ever a prototype for this machine? |
Post# 1154515 , Reply# 44   7/17/2022 at 10:21 (647 days old) by DADoES (TX, U.S. of A.)   |   | |
Sun 07/17/2022 -- Whirlpool, dated 11/29/1983, filed 09/14/1982. If I'm following the complex details correctly .... a liquid pumping agitator with, in the barrel, a manual-clean filter screen, a diluting rinse additive dispenser, and ports to provide an umbrella shower spray during agitation. Water pumps up the barrel during agitation for filtering and to dilute the rinse additive (dilution flow into the cup stops by weight when it's full so it doesn't overflow) for centrifugal dispensing after the first spin, and the pumped, filtered water showers back into the tub. Pumped water again fills the rinse additive cup during rinse agitation to flush it clean (and the rinse water then centrifugally drains out when the final spin ends). Seems a flaw is that detergent water during the wash period dilutes the rinse additive, which liquid softener and detergent are incompatible. Also, the lower part of the spun clothes load will get dampened when the rinse water collected into the rinse additive cup for cleaning it drains out after the final spin. Am I wrong? |
Post# 1159902 , Reply# 45   9/19/2022 at 09:23 (583 days old) by DADoES (TX, U.S. of A.)   |   | |
Mon 09/19/2022 -- Bendix Home Appliances, dated 04/14/1942 (filed 11/21/1938). Frontloader with onboard water heating (electric or gas) to provide a profile wash suitable for treating soils that respond to different temperatures. Note it references an initial warm fill of 110°F (suitable for washing delicates such as woolens), then optionally heated as the wash period progresses to a hot temperature such as 160°F for cotton materials. |
Post# 1159905 , Reply# 46   9/19/2022 at 09:47 (583 days old) by Golittlesport (California)   |   | |
Post# 1159906 , Reply# 47   9/19/2022 at 10:02 (583 days old) by qsd-dan (West)   |   | |
Post# 1160120 , Reply# 48   9/22/2022 at 07:07 (580 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1160125 , Reply# 49   9/22/2022 at 08:33 (580 days old) by Unimatic1140 (Minneapolis)   |   | |
This patent is very interesting. The Apex and Universal brands both used a wobbling/bouncing basket wash action, and while many of the parts are similar they are not the same. The drive mechanism in the Universal is completely different than the drive mechanism in the Apex. What this patent is is the Universal's drive mechanism. I suspect Universal bought the rights to use some of the design of the Apex yet for whatever reason decided on making their own unique drive mechanism.
Gosh it would be an absolutely amazing find to find a Universal automatic washer. As rare as the Apex machines are the Universal is 100 times more rare! Edit: WOW I just started to read some of this patent. It appears that Universal uses a perforated tub with a recirculation system instead of a solid tub like the Apex! This wash system was like a top-loading Kenmore/Whirlpool combo but with a bouncing basket! Here is the Universal's Drive System pictures 1 and 2 vs the Apex drive mechanism picture 3... |
Post# 1166927 , Reply# 50   12/18/2022 at 11:01 (493 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1178369 , Reply# 51   4/17/2023 at 10:51 (373 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1179279 , Reply# 52   4/28/2023 at 10:39 (362 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1190391 , Reply# 53   9/21/2023 at 10:01 (216 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1194422 , Reply# 54   11/30/2023 at 12:01 by DADoES (TX, U.S. of A.)   |   | |
Post# 1194762 , Reply# 55   12/5/2023 at 10:28 by DADoES (TX, U.S. of A.)   |   | |
Tue 12/05/2023 -- Gorman-Rupp Industries, dated 11/08/1960 (filed 10/04/1957). Self-cleaning filter design. Gorman-Rupp is a long-time manufacturer of pumps for a wide range of applications. |
Post# 1195367 , Reply# 56   12/14/2023 at 09:45 by DADoES (TX, U.S. of A.)   |   | |
