Thread Number: 87291
/ Tag: Modern Dishwashers
New Miele G 7000 dishwasher with PowerDisk |
Post# 1118746   5/30/2021 at 00:43 (1,055 days old) by mielerod69 (Australia)   |   | |
Hi Everyone,
My Miele G6827SCi had a total failure after only 3 years, Miele swapped the machine over for a new G7919SCi. So far, this machine is one of the best Miele dishwashers I have used. I was never very happy with the old model and I also thought something was never quite right with it. Anyway, Miele delivered the new machine and took away the old one. I installed it myself and here are some pictures. So far, I have tried a number of wash programs and everything comes out spotless, even hard baked on foods. The PowerDisk is very convenient and sometimes I still like to change detergents around. The machine is very quiet and I can't believe how it cleans so well with so little water. Each fill is around 3 litres and an Auto program uses 12 litres for a full cycle. If you select Extra Clean, the dishwasher will add a prewash if the cycle doesn't normally start with one as well as an additional rinse. The other feature this dishwasher has is SuperVison. I can track what the washing machine is doing from the control panel of the dishwasher. |
Post# 1118781 , Reply# 2   5/30/2021 at 13:34 (1,054 days old) by agiflow ()   |   | |
Did Miele switch to a plastic bottom arm now ? |
Post# 1118793 , Reply# 4   5/30/2021 at 15:15 (1,054 days old) by Jerrod_Six (Eastern Pennsylvania, USA)   |   | |
Henene Does your sensor wash already have a prewash or you mean it doesn't have one and extra clean will add one? MIeleRod - I would also like to know what problems you had encountered with your 6827 machine since I have a G6987 - six series also. |
Post# 1118795 , Reply# 5   5/30/2021 at 15:56 (1,054 days old) by henene4 (Heidenheim a.d. Brenz (Germany))   |   | |
Sensor decides of it needs a pre wash or not. High soil means a pre-wash, low soil skips it. Extra Clean will force this prewash even with a low soil condition. |
Post# 1118796 , Reply# 6   5/30/2021 at 16:25 (1,054 days old) by agiflow ()   |   | |
Just seems like cutting for corners for a company that is considered a premium brand. |
Post# 1118817 , Reply# 8   5/30/2021 at 19:54 (1,054 days old) by agiflow ()   |   | |
I didn't know that. Thanks ! |
Post# 1118820 , Reply# 9   5/30/2021 at 20:46 (1,054 days old) by Washingpowder (NYC)   |   | |
That's surprising. I have a G894 and the bottom arm is fully stainless. That said, I'm having issues with a sticking inlet valve so in considering repair vs buying a new one. |
Post# 1118821 , Reply# 10   5/30/2021 at 20:56 (1,054 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
What is the sequence for each program including the normal program? |
Post# 1118839 , Reply# 11   5/31/2021 at 00:26 (1,054 days old) by mielerod69 (Australia)   |   | |
Hi Jerrod_six,
SuperVision will only show the remaining cycle time on the dishwasher screen. You don't have the same functionality as the app. If you select the Express option with the Auto program, it now starts with a prewash, where in the G6827 it would start with the main wash. I also want to mention that the bottom spray arm holes are larger than the previous G 6000 series which I also think contributes to a better wash. The spray arms also work individually rather than top/bottom then middle, so 100% pressure in every wash arm. I have also attached the program sequence chart. I'm liking the QuickPowerWash with IntenseZone option. As I have my dishwasher connected to hot water, it only takes 60 minutes to complete or 48 minutes without any options.
Post# 1118894 , Reply# 15   5/31/2021 at 15:04 (1,053 days old) by Rolls_rapide (.)   |   | |
Ah, thanks. How long do the alternating spray arms operate for? |
Post# 1118895 , Reply# 16   5/31/2021 at 15:41 (1,053 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
How long does the normal program last? What's the sequence? |
Post# 1118933 , Reply# 17   6/1/2021 at 00:44 (1,053 days old) by mielerod69 (Australia)   |   | |
Hi,
Here is the pic of the bottom spray arm. The spray jets in the new model are larger than the previous G6000 series. @GELaundry4ever there is no Normal program. This has been changed to PowerWash, you can see the sequence in the program table. @Jerrod_Six the total failure was a slow internal leak that wasn't detected when the machine was only 18 months old and the heater relay went on it. The salt reservoir in the door must have been leaking for a while which caused the salt to build up under the machine and short out the dishwasher. This was only discovered when they came a second time and a senior tech came along and pulled the machine apart.
Post# 1118939 , Reply# 18   6/1/2021 at 05:30 (1,052 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
Why did they rename the normal program power wash? |
Post# 1118998 , Reply# 21   6/1/2021 at 19:11 (1,052 days old) by littlegreeny (Milwaukee, WI)   |   | |
Post# 1121570 , Reply# 23   6/27/2021 at 22:23 (1,026 days old) by mielerod69 (Australia)   |   | |
Post# 1131069 , Reply# 25   10/13/2021 at 17:48 (918 days old) by mielerod69 (Australia)   |   | |
Hi Everyone,
I'd like to show you how good this dishwasher cleans even the hardest baked-on food. I've been using this machine for quite a few months and its performance has been outstanding. This was a load I did last night with four casserole dishes with baked-on residue. Selected the Auto program with IntenseZone 2.25 hours. The machine used just 0.8 kWh and 11 liters of water. I have the detergent set to 5.5 grams (default is 7 grams), the water softener set to 6 dH, and the rinse aid set to 1 ml. |
Post# 1131075 , Reply# 27   10/13/2021 at 18:58 (918 days old) by lakewebsterkid (Dayton, Ohio)   |   | |
Glad to hear the 7 series is doing great! Do you have any issues with items in the middle of the bottom rack not being clean? It looks like there is a big gap in spray coverage of the wash arm. Keep us updated. |
Post# 1131087 , Reply# 28   10/14/2021 at 00:00 (918 days old) by mielerod69 (Australia)   |   | |
Post# 1131090 , Reply# 29   10/14/2021 at 03:15 (917 days old) by Logixx (Germany)   |   | |
Post# 1131129 , Reply# 30   10/14/2021 at 16:02 (917 days old) by Jerrod_Six (Eastern Pennsylvania, USA)   |   | |
Nice to see you are getting such good results with your DW and in a 2:25 run time! |
Post# 1136633 , Reply# 31   12/19/2021 at 23:27 (851 days old) by mielerod69 (Australia)   |   | |
Hi Everyone,
Following on temperature profile tests on heat pump dryers. I decided to do the same test in my Miele dishwasher. I ran two different programs and this is what I found. Auto 45 -65 C + IntenseZone option. Running time 2 hours 34 minutes. Hot water connection. Prewash - 30C Main wash - 50C, then further heating to 57C during IntenseZone phase Final rinse - 61C QuickPowerWash + IntenseZone. Running time: 1 hour 4 minutes. Hot water connection Main wash - 68C, then reheat to 68C during IntenseZone phase Final rinse - 65C The QPW impresses me with even baked-on dishes coming out spotless clean in around 1 hour. Amazing! |
Post# 1145591 , Reply# 33   3/31/2022 at 03:41 (749 days old) by Logixx (Germany)   |   | |
