Thread Number: 87375
/ Tag: Modern Dryers
Found These On The Scrap Pile This Week |
Post# 1119384   6/5/2021 at 13:02 (1,047 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
A Pair of Fisher & Paykel W&D, The dryer is electric, anyone know how old they are ? |
Post# 1119389 , Reply# 1   6/5/2021 at 14:46 (1,047 days old) by Repairguy (Danbury, Texas)   |   | |
Post# 1119412 , Reply# 3   6/5/2021 at 18:46 (1,047 days old) by DADoES (TX, U.S. of A.)   |   | |
Same washer model WL26CW1 that I picked up on 3/5 and refurbed. Serial on mine is LYU808667. This AquaSmart version has detergent and softener dispensers, no bleach. Bleach option is available on the Whites cycle, it stops and beeps 9 mins into the wash with the display advising to pour diluted bleach into the detergent funnel and press Start to continue. I also have a newer model version (S/N June 2009) with three dispensers. |
Post# 1119413 , Reply# 4   6/5/2021 at 19:07 (1,047 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 1119416 , Reply# 5   6/5/2021 at 19:34 (1,047 days old) by DADoES (TX, U.S. of A.)   |   | |
I'm not clear on your reference to funny agitator. Do you mean the EcoSmart agitator toploaders? AquaSmart has fully variable water level, not limited to 5 levels like the EcoSmart. Basket float is the primary factor for HE fill level, but there's also a minimum level. Basket float level is a factor in the calcuation for agitation speed. Most cycles that can run on deep fill (non-HE mode) run some agitation at HE level to check motor load resistance for calculating the deep fill level. The various Bulky cycles fill higher by default. Sheets cycle is kinda odd in that it fills to a fixed non-HE level, agitates a bit, then drains some water, apparently to attain appropriate impeller contact. Runs three repeating agitation actions, aim is to avoid tangling. Two sets of sheets washes better than one set IMO. There are several AquaSmart videos on my YouTube. Wash action is quite good IMO, better than the lethargic action of many newer HE impeller machines, and the wash period isn't as long (12 to 15 mins is typical). Rinsing takes up most of the cycle time. I sent documents with a bunch of technical design detail about both AquaSmart and AeroSmart to the email addy on your AW profile. Some of it may be F&P marketing propaganda. :-) |
Post# 1119570 , Reply# 6   6/7/2021 at 07:44 (1,045 days old) by vacerator (Macomb, Michigan)   |   | |
"Clyde Ohio" on the I.D. plate. Assembled under license by Whirlpool. |
Post# 1123370 , Reply# 7   7/15/2021 at 19:17 (1,007 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1123384 , Reply# 8   7/16/2021 at 05:54 (1,006 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 1127147 , Reply# 9   8/29/2021 at 00:28 (963 days old) by MaytagNeptune (FireAlarmTechGuy4444 on YouTube. Interlochen MI)   |   | |
Post# 1127160 , Reply# 10   8/29/2021 at 09:49 (962 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
