Thread Number: 87546
/ Tag: Modern Dryers
could anyone help me pinpoint the problem before call to a service tech is made or consider replacem |
Post# 1121111   6/23/2021 at 10:09 (1,035 days old) by Pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
hello to all aw before a call to a service tech is made or replacement considered could anyone help me pinpoint the problem no error code but i suspect its the control board its a 17 year old g1 duet purchuse in 2004 put a load in the dryer press start 1 second later dryer stop sensor light remians on but no tumbeling including a video taken with ipad
Post# 1121114 , Reply# 1   6/23/2021 at 10:44 (1,035 days old) by Yogitunes (New Jersey)   |   | |
Post# 1121125 , Reply# 2   6/23/2021 at 11:29 (1,035 days old) by DADoES (TX, U.S. of A.)   |   | |
There's a safety switch that prevents the machine from starting if the belt breaks but the control panel probably still otherwise operates. Check if the drum turns by hand easier than it should. Or take off the top panel (screws at the corners on back) to check if the belt is broken. It's (normally) visible wrapped around top of the drum. Won't be there if it broke and fell down to the bottom. Or could still be laying around top of the drum but loose, not engaged to the motor and idler pulley. |
Post# 1121131 , Reply# 3   6/23/2021 at 12:19 (1,035 days old) by Pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
Post# 1121286 , Reply# 4   6/24/2021 at 20:12 (1,034 days old) by SwedesApplServ (Cheyenne, WY)   |   | |
You may also have a failed solder joint on the motor relay. This is located on the control/relay board. I would resolder these when I found them on service calls, but sometimes you get lucky and it is a belt switch. |
Post# 1121295 , Reply# 5   6/24/2021 at 21:31 (1,034 days old) by Pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
will see after 17 years might replace the set will see set thats number 1 on mylist
Post# 1121376 , Reply# 6   6/25/2021 at 14:52 (1,033 days old) by panasonicvac (Northern Utah)   |   | |
Personally and this is just in my opinion, I would try and have the Duet fixed if you can. I've used both the TR7 and the Duet. While I like the TR7, however though, I personally like the Duet better. I've even used a pre 2017 SQ top loader before and I still like the Duet better. It cleans better, it uses less water, and it's slightly more energy efficient. Plus it probably would be cheaper to repair it anyways. Speed Queen just recently raised their prices this year. And what if you wouldn't like the SQ and you wanted the Duet back? To me that is a risk. But ultimately it's up to you and I wish of you the best of luck on your decision.
Post# 1121431 , Reply# 7   6/26/2021 at 02:53 (1,033 days old) by Chetlaham (United States)   |   | |
