Thread Number: 87594
Need to replace Mav4755aww agitator/auger but it’s part number is discontinued |
Post# 1121613 , Reply# 1   6/28/2021 at 13:39 (1,031 days old) by Yogitunes (New Jersey)   |   | |
your machine is a Norge design machine.....badged by Maytag....as in not a true Maytag....
so the standard Maytag pitman or orbital transmission agitators wont fit.... basically there were only two that fit this machine, a solid straight vane, or the 2 piece auger version.... what does concern me is you mention that because the auger is not working that it is locking up the transmission.....auger functioning or not, will not cause the trans to lock up...you may have more issues going on than the agitator.... these machines are prone for two things, transmission issues and pump failures... CLICK HERE TO GO TO Yogitunes's LINK on eBay
Post# 1121637 , Reply# 3   6/28/2021 at 17:13 (1,031 days old) by Yogitunes (New Jersey)   |   | |
how about a pic of your agitator....
and/or how does it differ from the one pictured?.... there were some variants to the auger/fabric softener.....but the base on all were the same... for the most part, these were not serviceable, as in replacing the dogs or being able to disassemble them...if it malfunctioned, which was rare, you replaced the whole agitator... |
Post# 1121642 , Reply# 4   6/28/2021 at 17:58 (1,031 days old) by ranand (New Jersey )   |   | |
Look similar but has the fabric softener cup. Some websites show the auger 27001230 and relevant kits 285811 but this 27001230 is not serviceable.
Post# 1121645 , Reply# 5   6/28/2021 at 18:18 (1,031 days old) by Yogitunes (New Jersey)   |   | |
go to the link I posted....
you can ask and verify for yourself if this agitator will fit your machine... but just the same, you have a MAV/Norgetag machine.....there were not many agitators that were offered.... although by different models, there were some variables of the auger..... these are held in place by a bolt, located down in the center of the auger... |
Post# 1121647 , Reply# 6   6/28/2021 at 18:45 (1,031 days old) by DADoES (TX, U.S. of A.)   |   | |
P/N 285811 repair kit is not for your agitator. It's for a different design used on Whirlpool, Kenmore, Roper, etc. Possibly some Maytag models produced by Whirlpool after 2006 but not yours. 285565 agitator won't work. It's Whirlpool which among other differences mates to a taller transmission drive shaft, your drive shaft is too short. 22001821 or 22004042 linked at eBay may or may not work. Can't tell from the photo if yours has a shallower base. Maybe someone else knows for sure, or you could take a chance on buying one or the other to check the fit yourself (that eBay seller takes returns for 30 days). As mentioned above, a problem with the auger should not make the transmission jam. The auger mechanism does not connect directly to the transmission, it sits passively atop the agitator base and is driven (in one direction, free-spins in the other direction) only by the oscillation of the base. The pump can break internally in a way that can cause it to jam which can impair agitation or spin or both. Or the transmission can break internally. Can you take a video of the agitation problem? Can't upload videos into posts here like a photo ... put the video on YouTube or other sharing site (make sure it's not set to private view) and place a link to it in a reply. |
Post# 1121746 , Reply# 8   6/29/2021 at 11:17 (1,030 days old) by ranand (New Jersey )   |   | |
The eBay seller suggests that this doesn’t fit. For the base comparison, is it the pitch of the cone that determines the fit? |
Post# 1121898 , Reply# 10   6/30/2021 at 14:41 (1,029 days old) by Yogitunes (New Jersey)   |   | |
Post# 1121903 , Reply# 11   6/30/2021 at 15:03 (1,029 days old) by ranand (New Jersey )   |   | |
In the case of the top of front I would prefer the front loader. For the drives which is the more gentle on the clothes. This washer was rough. |
Post# 1121923 , Reply# 12   6/30/2021 at 17:13 (1,029 days old) by Yogitunes (New Jersey)   |   | |
Post# 1121925 , Reply# 13   6/30/2021 at 17:29 (1,029 days old) by ranand (New Jersey )   |   | |
The pricing I saw for the speed queen looks like the top or front loaders are a couple of thousand. Any budget recommendations? |
Post# 1121956 , Reply# 14   6/30/2021 at 21:13 (1,028 days old) by Yogitunes (New Jersey)   |   | |
you get what you pay for....it is your money, and your choice
you already have the budget version of a Maytag, and where did that leave you? most appliances today dont have a long life cycle, its hit or miss, and there are a few exceptions, but most only last 3 to 5 years, and maybe upwards of 7.....usually once the short warranty runs out... if anything, invest in a good extended warranty, your going to need it...better to have it and not need it, than to need it and not have it....Lowes offers an interesting extended warranty, if you dont use it, they will refund 2/3rds the price to you at the end of the term.... take a ride behind Lowes or HomeDepot, and see how many machines are there sitting in the scrap pile.... |
