Thread Number: 87603
Wascomat Flex O Matic |
Post# 1121666   6/28/2021 at 23:04 (1,003 days old) by HobartHero (New York)   |   | |
So I have 2 of these machines in an old maids room of the property I run. I think both don’t need much to run. I believe an inlet valve is stuck open on one machine and I’m not sure either machine advances the cycle cards to run a complete wash beginning to end and therefore it sometimes stays on a single part of the wash. Can I eliminate the old card system for something simpler like a cycle selection switch? These are commercial machines so I’m assuming parts won’t be as difficult to find. Any help s greatly appreciated.
-Shannon
Post# 1121883 , Reply# 1   6/30/2021 at 12:34 (1,002 days old) by ozzie908 (Lincoln UK)   |   | |
Are usually pretty reliable if the card remains in one place it could be a part of the card is worn and is slipping, Would these be heated versions? That makes them stay in one place as they heat and also its worth giving the card and the reader a clean as dust and fibres clog it up.
Am sure a man of your talent would be able to make a good machine out of the 2 :) Good luck and keep us posted. Austin |
Post# 1121929 , Reply# 2   6/30/2021 at 18:06 (1,001 days old) by HobartHero (New York)   |   | |
Post# 1121933 , Reply# 3   6/30/2021 at 18:59 (1,001 days old) by Tomturbomatic (Beltsville, MD)   |   | |
Machines in a commercial property might run on 208 V. |
Post# 1121971 , Reply# 4   7/1/2021 at 01:55 (1,001 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Wascomat made other models of washing machines at time, but Flex-O-Matic was it far as card reading washers was concerned.
Card reading washers were everywhere on commercial and even some domestic h-axis washing machines at one time. They filled a niche until microprocessor/computer and or "electronic" machines came along. www.manualslib.com/produc... |
Post# 1121974 , Reply# 5   7/1/2021 at 03:22 (1,001 days old) by HobartHero (New York)   |   | |
