Thread Number: 87837
Can someone date this please |
Post# 1124083   7/25/2021 at 13:20 (1,005 days old) by ozzie908 (Lincoln UK)   |   | |
I have no idea what its age is and found no dates inside when it was apart so can one of you kind folks date this washer?
It says American gold collection on the console. Austin |
Post# 1124087 , Reply# 1   7/25/2021 at 14:24 (1,005 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1124653 , Reply# 2   8/1/2021 at 13:38 (998 days old) by ozzie908 (Lincoln UK)   |   | |
Post# 1125596 , Reply# 3   8/12/2021 at 06:00 (987 days old) by ozzie908 (Lincoln UK)   |   | |
When its done the rinse and taken in the fabric conditioner why does it do a spray rinse during the final spin ? Surely that's going to dilute the FS even further? I used it yesterday did a hot wash and noticed when folding the laundry that dark items had lint bobbles, I am assuming there is no lint filter?
I admit I have only used a Maytag TL before and that did a spray rinse before the deep one which makes more sense. Austin |
Post# 1125625 , Reply# 4   8/12/2021 at 12:13 (987 days old) by DADoES (TX, U.S. of A.)   |   | |
The timer is programmed for a spray in the final spin. No way to change that regards to whether or not softener is used without a revised timer and an added softener option with a switch to bypass the spray cam circuit. GSC9455J doesn't search as a direct equivalent US model to check for sure ... but it probably has a passive lint filter (photo) attached to the underside of the spin basket. Pumping action of the agitator pulls water through the filter during agition, collected lint is flushed off during spin. They really don't work all that well and the filtering fingers eventually get clogged with mineral residue and lint that doesn't flush off. The under-basket filter was later replaced by four little plugs (video) that fit from the top into the water pump-through holes under the agitator. Some models later after the revision elimated the plugs and had nothing regards to filtering.
Post# 1125685 , Reply# 5   8/13/2021 at 06:58 (986 days old) by ozzie908 (Lincoln UK)   |   | |
Thank you so much, You Sir are an absolute mine of information :)
I attach a couple of pics of said washer maybe it was a UK exclusive or something? Austin |
Post# 1125696 , Reply# 6   8/13/2021 at 10:14 (986 days old) by DADoES (TX, U.S. of A.)   |   | |
