Thread Number: 87893
What happening to my washing machine? |
Post# 1124652 , Reply# 1   8/1/2021 at 13:23 (991 days old) by ozzie908 (Lincoln UK)   |   | |
A picture would be good if your able to get one of the damage? IMHO it sounds like the drum is flexing and the area where the spider is bolted is usually under the paddles so unless they are loose you won't see anything ?
Show us what's happening and someone may know what you can do about it !! Austin |
Post# 1124671 , Reply# 2   8/1/2021 at 17:07 (991 days old) by Rolls_rapide (.)   |   | |
I'm assuming the aluminium alloy drum-spider is fractured. Does the drum revolve smoothly, or is it off-centre/wobbly/eccentric motion? |
Post# 1124764 , Reply# 4   8/2/2021 at 17:50 (989 days old) by cfz2882 (Belle Fourche,SD)   |   | |
that sure looks like corrosion on the backside is starting to break through-perhaps lint and gunk has built up between the corrosion and the aluminum spider-causing a galvanic effect. |
Post# 1124792 , Reply# 5   8/3/2021 at 04:59 (989 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Morning Paul , wow it does look as Brendan said above some galvanic corrosion going on , which although your Bosch is nearly 25 yrs old ? have never seen happen like that in a Bosch etc weakening and breaking through the stainless steel drum. .
Its probably the spider thats causing the problems only way through that is a replacement spider , drum and bearings while your at it for good measure. Why not drop Chris (The Laundry Centre ) a message see if hes come across any scrapper machines / parts etc or scrapper machines if your wanting to keep it . Is this your daily driver ? Cheers, Mike
Post# 1124817 , Reply# 7   8/3/2021 at 13:47 (989 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Well its certainly given you stellar service hast it , looking around for 7kg, 1400rpmwith Speedperfect to get the time down and Currys have one for £379 , Ive been using Johns new Series 8, 10kg load, 1600 spin , fabulous washer , with induction motor etc.
I think Bosch are on the up again with their quality and features, good luck and let us know how you get on !! Cheers, Mike CLICK HERE TO GO TO chestermikeuk's LINK |
