Thread Number: 87970
cold/warm spray |
Post# 1125430   8/9/2021 at 14:31 (983 days old) by lovestowash (St. Petersburg, FL)   |   | |
Searching craigslist for a Kenmore washer like I had in Atlanta, and discovered this model, with an unusual rinse option...
Post# 1125432 , Reply# 1   8/9/2021 at 15:00 (983 days old) by RP2813 (Sannazay)   |   | |
Very interesting. I would select that setting a lot.
I used to set our Maytag A206 for a hot wash after filling on warm -- particularly when washing towels -- in order to get a warm spray rinse, which added volume to the spray. I was disappointed when I found out that the A712 I got a few years ago only provided a cold spray regardless of wash temperature. |
Post# 1125433 , Reply# 2   8/9/2021 at 15:07 (983 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1125434 , Reply# 3   8/9/2021 at 16:12 (983 days old) by Yogitunes (New Jersey)   |   | |
it was in part for people who didn't understand, and would call for service(which they had to pay for if there was nothing wrong with the machine) alerting them that this selection gave them a cold deep rinse, and the spin/spray was warm...
for many setups, the hot water in the pipes has cooled down by the time it called for the spray rinse...so you got a full flow of cold water from both sides, by the time the hot water got to the machine, the spray ended....unless your machine was located very close to the water heater, or found a way to purge the line before the final spin started.... |
Post# 1125441 , Reply# 4   8/9/2021 at 18:44 (983 days old) by lakewebsterkid (Dayton, Ohio)   |   | |
Very true! I often would switch our DD to warm/warm after the rinse filled so that it would force a higher volume spray rinse. As mentioned, this is for sure due to energy guidelines. |
Post# 1125443 , Reply# 5   8/9/2021 at 19:36 (983 days old) by chetlaham (United States)   |   | |
