Thread Number: 88074
/ Tag: Vintage Dryers
In regards to drying… |
Post# 1126575 , Reply# 1   8/22/2021 at 08:33 (970 days old) by Pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
my advice is if you can line dry or have a clothes rack like this for small loads if its day time line dry or if its something you need for the next day then use the clothes rack and use the dryer for bigger load unless your dryer has a time dry cycle that you can set for 30 0r 20 minutes or less depending on load size
Post# 1126581 , Reply# 2   8/22/2021 at 10:09 (970 days old) by Combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 1126592 , Reply# 4   8/22/2021 at 13:38 (970 days old) by arbilab (Ft Worth TX (Ridglea))   |   | |
After the twinny spinny I hang towels over the showercurtain rod. By the time everything else is done they are dry enough to use (if a bit clammy). The dryer finishes everything off in 15min. Except socks, which get to lay out till the next afternoon then put away.
In Hawaii, never had a dryer, never missed it. But half the time in Hawaii I scarcely had clothes either. |
Post# 1126599 , Reply# 5   8/22/2021 at 15:57 (969 days old) by DADoES (TX, U.S. of A.)   |   | |
How long is a reasonable time to machine dry a queen size quilt?
Post# 1126600 , Reply# 6   8/22/2021 at 16:10 (969 days old) by Yogitunes (New Jersey)   |   | |
Post# 1126604 , Reply# 7   8/22/2021 at 17:10 (969 days old) by DADoES (TX, U.S. of A.)   |   | |
