Thread Number: 88087
/ Tag: Vintage Dishwashers
Kitchenaide Imperial 21 dishwsher |
Post# 1126714 , Reply# 1   8/24/2021 at 12:40 (947 days old) by Combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Likely a problem with the program switch or the door switch, if you’re handy and wanna open it all up you can look for bad wiring connections on the door switch or the door switch itself.
When you latch the door and press one of the cycle buttons there’s a mechanical system that pops the button back out when you open the door does the button still pop out nicely when you open the door? There is also a little pen on the upper right hand corner of the tank that presses into our opening on the door to activate the door switch make sure that pin is in place and making the switch click as you push the door closed all the way. Other than these things it’s hard to make suggestions without knowing your mechanical ability etc. Good luck and let us know what you find. John |
