Thread Number: 88088
FSP / Whirlpool Timer 20055515 / 359312 |
Post# 1126810 , Reply# 1   8/25/2021 at 13:37 (946 days old) by Combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
These are not easy things to fix although not impossible but I personally would never bother trying to rebuild a timer like this.
Hopefully you can find a replacement It’s more often the little switch contacts and leaves that fell off and you can clean a contact and adjust it, even though the gray cam looks bad usually they’re OK. And even if there is a small defect in the gray cam you could build it up with Epoxy and use a Dremel to fix it. John |
