Thread Number: 88114
/ Tag: Twin-Tub Washers
Bakelite bolt removal |
Post# 1126983 , Reply# 1   8/27/2021 at 08:24 (966 days old) by Unimatic1140 (Minneapolis)   |   | |
Post# 1126984 , Reply# 2   8/27/2021 at 08:48 (966 days old) by gizmo (Victoria, Australia)   |   | |
I'd try pouring boiling water on it to expand the nut. I'd be worried about using a heat gun. Maybe a hair dryer? Also soak it in Inox spray. I love the stuff, it's magic. CLICK HERE TO GO TO gizmo's LINK |
Post# 1127098 , Reply# 4   8/28/2021 at 14:23 (965 days old) by Brisnat81 (Brisbane Australia)   |   | |
Hey Adam. I can’t help with the removal, but 10cm3 is 10mls, that is 2 teaspoons of grease. |
Post# 1127116 , Reply# 5   8/28/2021 at 19:00 (964 days old) by Adam-aussie-vac (Canberra ACT)   |   | |
That makes much more sense It’s alright I’ll figure something out, I’m just wanting to break off the Bakelite that’s all |
Post# 1127128 , Reply# 6   8/28/2021 at 20:59 (964 days old) by Adam-aussie-vac (Canberra ACT)   |   | |
I’m just not wanting* |
Post# 1127152 , Reply# 7   8/29/2021 at 07:09 (964 days old) by ozzie908 (Lincoln UK)   |   | |
I am assuming the bakelite nut is just a cover for the steel nut/bolt underneath ? Would it be to stop rust marking the clothes? If this is the case you could try splitting it in two so you can access the nut and then glue it back together afterwards? Did similar to a Rolls spin can it was the only way to get it off.
Good luck Austin |
Post# 1127226 , Reply# 8   8/30/2021 at 06:52 (963 days old) by Adam-aussie-vac (Canberra ACT)   |   | |
But I want to grease the bearings,And you’re supposed to put about 8 ml to 25 mlof grease Into the bearings |
