Thread Number: 88180
/ Tag: Vintage Dishwashers
Hobart/Kitchenaid KDI-58- how to build in? |
Post# 1127699 , Reply# 2   9/4/2021 at 07:40 (958 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
As Tom mentioned you can not remove the outer cabinet so you might have to cut holes through the sides to run water, drain and electrical lines to connect it, also keep in mind that with the cabinet these DWs are slightly larger than a regular 24" built-in DW, so it might not fit where a regular BI machine was installed.
Post# 1127715 , Reply# 3   9/4/2021 at 11:16 (958 days old) by steved (Guilderland, New York)   |   | |
Here's the conversion instructions: |
Post# 1127755 , Reply# 6   9/4/2021 at 19:44 (958 days old) by DADoES (TX, U.S. of A.)   |   | |
