Thread Number: 88230  /  Tag: Vintage Automatic Washers
Front loading washing machine with gearbox/transmission
Post# 1127931   9/6/2021 at 22:11 (952 days old) by Adam-aussie-vac (Canberra ACT)
Hey guys, has anybody either owned or used a washing machine with a transmission/gearbox? As earlier today I picked up a timesaver washing machine which does have a gearbox in between the motor and the drum, Has anybody else seen a washing machine designed like this?
Post# 1127938 , Reply# 1   9/6/2021 at 23:50 (952 days old) by gizmo (Victoria, Australia)
Hold on a minute... Where are all the other photos? You can't get away with just that photo!
Bendix front loaders for a start had a gearbox.
Hoover (slope front) Keymatics had a reduction gear on the end of the motor, and the other end of the motor had a pulley that turned at motor speed. The machine switched from tumble to spin by switching from the motor-speed pulley (fast pulley) to the reduction gear (slow) pulley. (this achieved by reversing the motor.)
Post# 1127942 , Reply# 2   9/7/2021 at 05:40 (952 days old) by Adam-aussie-vac (Canberra ACT)
Okay okay, I’ll grab more pictures
And this machine is not at my house yet this is from another collector in Melbourne
Post# 1127945 , Reply# 3   9/7/2021 at 06:14 (952 days old) by aussie-plugs (Melbourne, Australia)
Fascinating machine ...
I'm sure when you do get it home we'd all like LOTS more photos.
I'm particularly curious as to brand and where made, what the dials do and the curious button beneath the door - drain plug/pump engagement?
Have fun when it arrives!
Post# 1127958 , Reply# 4   9/7/2021 at 12:59 (952 days old) by arbilab (Ft Worth TX (Ridglea))
arbilab's profile picture
Westinghouse used a gearbox semi-sporadically among models.  We had both.  The spin side of the gearbox quit after much use and was replaced.  Not long after, the machine was replaced by a newer one with 3 belts, intermediate tumble idler, and spin sheave directly on the motor shaft.  Again after much use, I replaced the spin sheave on the new one.
Easy enough for a kid to do without instructions or supervision.
Post# 1127961 , Reply# 5   9/7/2021 at 13:38 (952 days old) by simpsomatic (Melb, Aust-now Palm Springs,US)
Servex
Made washing machines, refrigerators, sewing machines and heavy equipment.
Check it out at GOOGLE: "servex washing machine australia"
Post# 1127966 , Reply# 6   9/7/2021 at 15:03 (952 days old) by turquoisedude (.)
turquoisedude's profile picture
GE's front-load washer-dryer combination units had a gearbox.  They had to do something to get the tub speed up to a blinding 208 rpm spin....LOL
Post# 1128006 , Reply# 7   9/7/2021 at 21:48 (951 days old) by Adam-aussie-vac (Canberra ACT)
Simpsomatic
Was it this machine?
Post# 1128021 , Reply# 8   9/8/2021 at 02:28 (951 days old) by aussie-plugs (Melbourne, Australia)
Other pictures too ..
Adam,
I'm guessing this is the State Library of WA URL you found that picture at. There are a couple of others too. The third shows a wall of other appliances of the day.
Thanks for leading us to it.
Cheers,
Nick
CLICK HERE TO GO TO aussie-plugs's LINK
Post# 1128029 , Reply# 9   9/8/2021 at 06:05 (951 days old) by simpsomatic (Melb, Aust-now Palm Springs,US)
Servex
Adam,
Yes this is machine. I tried to download the pictures but thought copyright was preventing. 1953 and look at all those men drinking beer watching the demonstration. Yes, other pictures showing appliances of the day, electric jug, canister vacuum cleaner and several models of the fake fireplace electric radiators. Of note the sign "What Australia Makes, Makes Australia". My neighbors had one of these machines, small capacity, bolt down, no suspension, manual controls and gravity drain hence the front drain tap. Cannot wait to see pictures.
Post# 1128415 , Reply# 10   9/12/2021 at 04:02 (947 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)
Washing Machine Gearbox Transmission
We have the Hoover Keymatic first series of washing machines which use a gearbox and transmission reduction system as Chris explained above.
  Photos...       <              >      Photo 1 of 8         View Full Size
Post# 1128416 , Reply# 11   9/12/2021 at 04:19 (947 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)
Gearboxs in washing machines
Bendix is the other main user of a little gearbox in their bolt down washing machines which uses a series of slip gears to achieve wash , distribution and spinning speeds.
Post# 1129452 , Reply# 12   9/23/2021 at 19:59 (935 days old) by Adam-aussie-vac (Canberra ACT)
ITS HERE
The machine had arrived and I unpacked it, everything works but I am not sure about the heater and unfortunately a little bit of paint came off when I removed the tape i’ve already ordered a part for it which is some 38 mm silicone tubing to fix the drain valve And I will upload a video to YouTube so you guys can hear how it sounds
CLICK HERE TO GO TO Adam-aussie-vac's LINK
Post# 1129471 , Reply# 13   9/24/2021 at 06:11 (935 days old) by aussie-plugs (Melbourne, Australia)
Good for you!
What a wonderful piece of Australian history. And years of enjoyment for you as you restore it and make it a proud part of your collection
Post# 1129479 , Reply# 14   9/24/2021 at 06:57 (935 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)
Ausie Wilcomat
Great work Adam, looks a fun machine to use with all the dials and controls, is it a bolt down model ? looks a cross between English Electric / Spacemates and Bendix.
Look forward to seeing it run, Enjoy the renovations !!
Post# 1129480 , Reply# 15   9/24/2021 at 07:07 (935 days old) by Adam-aussie-vac (Canberra ACT)
It is a bolt down Model, I will have to find
Somewhere where I can bolt it down, it will have a happy place in my collection and the funny thing was the collector I got it from got it out of a abandoned house, the house was torn down I think last year, If you’d like I could probably ask him if I can share the pictures of the Time Capsule of a house
Post# 1129484 , Reply# 16   9/24/2021 at 07:44 (935 days old) by Adam-aussie-vac (Canberra ACT)
He said yes
Here are the photos of the house that the machine was installed in
  Photos...       <              >      Photo 1 of 7         View Full Size
Post# 1129503 , Reply# 17   9/24/2021 at 15:11 (935 days old) by CircleW (NE Cincinnati OH area)
Interesting old house; the exterior reminds me of one I'd see in Tennessee or Mississippi.
Do you remember what brand the refrigerator is? It looks sort of like a Kelvinator we had at one time.
Post# 1129509 , Reply# 18   9/24/2021 at 17:02 (934 days old) by Adam-aussie-vac (Canberra ACT)
I recognise it as Electrolux
I wasn’t the one who took the photos, the collector in Melbourne I’ve got the washing machine out did I just asked him if I could post them here
Post# 1129517 , Reply# 19   9/24/2021 at 19:28 (934 days old) by gizmo (Victoria, Australia)
that fridge is Electrolux, an absorption fridge not compressor fridge, quite possibly a gas fridge.
Post# 1129535 , Reply# 20   9/24/2021 at 20:52 (934 days old) by CircleW (NE Cincinnati OH area)
Thanks for the reply. Guess it would be similar to a Servel refrigerator, which were advertised as being totally silent in operation.
Post# 1129544 , Reply# 21   9/24/2021 at 23:57 (934 days old) by Adam-aussie-vac (Canberra ACT)
i wonder
how would a fridge like that work?
Post# 1129548 , Reply# 22   9/25/2021 at 02:51 (934 days old) by Chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)
Gas Fridge
Was wondering if the box on top left is an exhaust chimney fitted to the outside for fumes to be vented outside ?
Post# 1129551 , Reply# 23   9/25/2021 at 05:56 (934 days old) by Adam-aussie-vac (Canberra ACT)
Oh, I wondered what that was
I thought it looked like someone cut up a bit of a mailbox and just shoved it there to keep the shelf up
Post# 1129559 , Reply# 24   9/25/2021 at 09:35 (934 days old) by gizmo (Victoria, Australia)
I reckon that looks like an outdoors vent for the fridge gases. Suggests it is an lpg fridge.
this 1939 film shows how a gas fridge works...
(actually the explanation is pretty terrible, but it is quaint...)
google "how gas fridges work" or "how absorption fridges work."
CLICK HERE TO GO TO gizmo's LINK
Post# 1129573 , Reply# 25   9/25/2021 at 13:04 (934 days old) by simpsomatic (Melb, Aust-now Palm Springs,US)
Kerosene
Interesting article
australianfoodtimeline.com.au/fi...
