Thread Number: 88323
Maytag designs |
Post# 1128913 , Reply# 1   9/17/2021 at 14:08 (950 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
Here's the oil for the Maytag washer. What weight is it? Is this what they used in their pitman and orbital transmissions? CLICK HERE TO GO TO GELaundry4ever's LINK |
Post# 1128915 , Reply# 2   9/17/2021 at 14:28 (950 days old) by qsd-dan (West)   |   | |
I don't believe Maytag ever announced the thickness of their oil; It was sort of a guarded secret for whatever reason. The stuff used in pre 1975 transmissions was pretty darn thick. My guess would be somewhere in the neighborhood of 140 using gear oil rating specs (motor oil and gear oil do NOT share the same ratings). The newer oil used in later pitman transmissions and Orbitals seems to be a tad thicker than conventional 90 weight oil, around the 100-110 weight mark. Those are my personal opinions, not facts. |
Post# 1128930 , Reply# 4   9/17/2021 at 16:59 (950 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
What did Maytag think of their competitors? CLICK HERE TO GO TO GELaundry4ever's LINK |
Post# 1128945 , Reply# 5   9/17/2021 at 21:48 (950 days old) by cfz2882 (Belle Fourche,SD)   |   | |
Earlier pittman trannys used straight-cut gear teeth,while the later used helical cut teeth-don't know when the change was made.I think the Orbital tranny started with 1989 production. |
Post# 1128951 , Reply# 6   9/17/2021 at 22:29 (950 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
What is the agitation like on the a9900? I saw a video of the Maytag digital washer from 1991. I wish I could see it going through a regular cycle with a full load of light colors if swestoyz still has this unit. CLICK HERE TO GO TO GELaundry4ever's LINK |
Post# 1128952 , Reply# 7   9/17/2021 at 22:31 (950 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
Wrong video. That was their rival. Let's try this again. CLICK HERE TO GO TO GELaundry4ever's LINK |
Post# 1128953 , Reply# 8   9/17/2021 at 22:40 (950 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
What weight of oil did Maytag use in their dependable care washers? |
Post# 1129044 , Reply# 9   9/18/2021 at 18:25 (949 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 1129047 , Reply# 10   9/18/2021 at 18:49 (949 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 1129087 , Reply# 11   9/19/2021 at 11:51 (948 days old) by robbinsandmyers (Conn)   |   | |
Post# 1129205 , Reply# 13   9/21/2021 at 10:30 (946 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
Why do the pumps on these Maytags and Whirlpools do that aerating noise during agitation? What is the point of that? I have noticed that on these 2 brands, while others don't, including GE. |
Post# 1129211 , Reply# 14   9/21/2021 at 12:51 (946 days old) by d-jones (Western Pennsylvania (Pittsburgh Area))   |   | |
Post# 1129216 , Reply# 15   9/21/2021 at 14:19 (946 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
I did notice that on Maytag orbitals as well as the whirlpool direct drive. What was the point of that? |
Post# 1129221 , Reply# 16   9/21/2021 at 15:23 (946 days old) by d-jones (Western Pennsylvania (Pittsburgh Area))   |   | |
The belt that drives the pump is driven by the same motor pulley that drives the transmission belt. When the motor reverses and the spin cycle begins, the pump turns in the correct direction to empty the water out. When the motor rotates in the forward direction, the transmission agitates and the pump harmlessly rotates in reverse. The idea was to keep things simple. |
Post# 1129222 , Reply# 17   9/21/2021 at 15:43 (946 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
It's interesting how these pumps were able to do this. I could've sworn Whirlpool did this too. I could've sworn I heard air flowing through the pump on a whirlpool direct drive and Maytags as well on their dependable care units. CLICK HERE TO GO TO GELaundry4ever's LINK |
Post# 1129225 , Reply# 18   9/21/2021 at 15:51 (946 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
Here's the whirlpool. CLICK HERE TO GO TO GELaundry4ever's LINK |
Post# 1129226 , Reply# 19   9/21/2021 at 15:55 (946 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
Here's the older version. I believe this was Maytag's rival. I could've sworn their pumps aerated like their maytag rival did. CLICK HERE TO GO TO GELaundry4ever's LINK |
Post# 1129241 , Reply# 20   9/21/2021 at 18:42 (946 days old) by DADoES (TX, U.S. of A.)   |   | |
Jerome, Whirlpool direct-drive and Maytag, the pump essentially is the same function. One pumping chamber, think of it as U-shaped. The tub outlet hose connects to one end of the U. The drain hose connects to the other end. The Maytag pump is a little different shape but it functions the same. Water flows from the tub outlet into the pump. The impeller is driven either clockwise or counterclockwise accordingly to which direction the motor is running ... agitate direction or spin direction. There's no way to disengage the pump from running whenever the motor runs on either type of machine. Agitate direction the impeller pushes the water back up into the tub. Spin direction it pushes the water out through the drain hose. Air can be pulled through the drain hose in the agitation direction and generate a cavitation noise, along with the impeller pushing the water up into the tub. Whirlpool had a rubber flapper valve on the pump outlet port for some models (KitchenAid for example) that closed it against sucking air to lessen the noise. |
