Thread Number: 88382
Miele W1 WXR 860 WCS Frustrations |
Post# 1129466 , Reply# 3   9/24/2021 at 02:18 (944 days old) by Stephen (Palm Springs CA USA)   |   | |
Hi. According to the manual you should be able to turn on the drum light on the WXR860.
Post# 1129470 , Reply# 4   9/24/2021 at 04:32 (944 days old) by Logixx (Germany)   |   | |
In Europe, the Shirts cycle includes steaming by default - maybe your other Miele didn't default to steaming? Same should be true for the Allergy option, which has a steam phase after the main wash (again, in Europe). Just some quick thoughts.
I also wonder what would happen if the machine is set to a different country. Will it still lock the user out of some settings? |
Post# 1129536 , Reply# 7   9/24/2021 at 20:58 (943 days old) by mielerod69 (Australia)   |   | |
I have an older Miele W1 WMR861WPS and I'm very happy with the machine. Like others, the imbalance system is more sensitive than my older W5965, but I put that down to the larger tub in the same casing. I can be a little annoying, but I'm used to it now.
1. I agree with the new app being useless and don't like any of the 'new' features. They have definitely gone backward here. 3. With the messages coming up, you should be able to swipe the screen up to make it disappear. I have a similar screen on the G7000 dishwasher. 4. This makes sense as it adds more or less detergent depending on the soil level. As you mention, you can adjust the wash parameters by adding a prewash, soak or use the stains option which will lengthen the program. 5. There should be a yellow bar at the top of the display that you should be able to drag down to see the consumption during the program. Again, with my dishwasher, this can be a little difficult to drag the screen down. 6. Yes, normal is the energy program, so they probably lock that feature out. Again the instruction book is not always accurate. 7. Agree, but not a big issue anymore. 8. The length of time could be due to the temperature of the incoming water 9. Not an important point for me. 10. This could be due to load size and incoming water temperature. If you wash 5 shirts, you can enable the 'single wash' option as it's good for up to 1 kg (2.2 lbs) of laundry. 11. I have 10 favourites and it works for me. |
Post# 1129552 , Reply# 9   9/25/2021 at 06:09 (943 days old) by ozzie908 (Lincoln UK)   |   | |
I don't have any of the issues the OP mentioned nor do I have the top of the line model its now 2 years old and has been used daily, Never an issue with spinning it even does it with towels and bathmats, I can add extra rinse and water levels if required but I trust it to know how much water it needs and it just gets on with it. I have got used to it being different to the W9444 I had before which although both having the 1600 the W1 seems to spin longer at top speed, It does not have WIFI nor TwinDos I did not want either as I use powder for whites and liquid for colours both of which I change at times and did not want to be tethered to Miele products. Have had Tech out 2x as there was a glitch in the program and although it did not drain when you added an item it would skip the majority of the wash cycle and go straight to rinse..... Its sorted now and I don't miss my old one anymore I don't think it will last 10 years but if not I won't buy another I will dig about and find a used one if I have to. The pic is before I plumbed it in.
Austin
Post# 1129692 , Reply# 12   9/26/2021 at 19:11 (941 days old) by mielerod69 (Australia)   |   | |
Post# 1129778 , Reply# 15   9/27/2021 at 17:54 (940 days old) by mielerod69 (Australia)   |   | |
Hi Steve,
I find it does the same with my model. I have extra rinse and water plus active and find it rinses well. I have adjusted the water plus level to three drops on the menu. I assume the short option is geared for lightly soiled laundry and therefore less detergent would be used. If you use the short option with Minimum Iron, it spins between each rinse and not just a short burst spin. |
Post# 1129837 , Reply# 16   9/28/2021 at 14:55 (939 days old) by stevefromsydney (London)   |   | |
Thanks Mielerod69, Nice to know my machine doesn't have a blip in the programming. How strange that on some models it spins after every wash on short and on others it doesn't. |
Post# 1130082 , Reply# 18   10/1/2021 at 11:49 (936 days old) by derrick352 (United States Of America)   |   | |
Wow already flaws in new units just rolled out. Miele cannot fix the prewash on prior models, now the bleach dispensing is useless in the new ones. WTF is wrong with Miele? They won't even acknowledge the issues. Total BS. Subject drift is laughable as posted on miele.usa. |
Post# 1130142 , Reply# 19   10/1/2021 at 22:42 (936 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
"Does anybody know how to contact a competent person at Miele USA?"
There really doesn't seem to be a way sadly, everything is pretty much luck of the draw. Have said MieleUSA had a huge shake-up of upper management along with other changes. Results have been a mixed bag, but plenty of people left the company. Cannot be sure but it seems even before covid Miele had begun outsourcing customer service to some place in India (call center). This or making large use of CSR who work from home. Last few times have reached out to Miele customer support have gotten reps who "are having problems with their computer", another was wheezing, sneezing, coughing, snorting, blowing her nose, sniffling.. all while banging away at computer keyboard but couldn't understand my question (I hung up). What is apparent is MieleUSA has separated out technical support from customer service. Days of getting a real Miele tech on phone when calling CS are over. You get someone with limited access to system and they really only know what is in front of them on screen. Last few email CS requests one has made follow similar pattern; they are first read by someone in "Miele Professional Division", then forwarded to a lower tier person in (email says Princeton, NJ offices) but one has doubts as names are always Indian. www.mieleusa.com/m/964.ht... www.glassdoor.com/Reviews/Miele-... mymieleexperience.com/my-story/... FWIW here is job listing from about five years ago for Miele CSR inbound: www.disabledperson.com/jo... And here are reviews by some CSR working for MieleUSA at that time. www.indeed.com/cmp/Miele/... Latest posting as of August 2021: www.helpwanted.com/aa8911... Am not painting all Miele CSR with bad wide brush, and lord knows over past two decades have had my share of "bad" communications even with "old" system. But at least back then one stood a decent chance of getting a tech on phone who cared, knew about appliance in question and could walk you through some DIY bits. |
Post# 1130150 , Reply# 21   10/2/2021 at 07:28 (936 days old) by henene4 (Heidenheim a.d. Brenz (Germany))   |   | |
If you have an IntenseWash equipped washer, turning that off will also switch off the IntenseWash algorithm. Recirculation will still be active, however. |
Post# 1130198 , Reply# 23   10/2/2021 at 20:29 (935 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
" I always assumed the machines just used a thermostat to ensure that the target temperature was achieved."
Sadly that is not true, nor has been for some time now, at least for washing machines sold in Europe. Days of thermo-stop settings on timers or whatever that will hold things until set temperature is reached seems to have gone way of Dodo. Some machines will hit set/target temperature, others don't. And when the latter doesn't it can be off by more than a few degrees. www.ukwhitegoods.co.uk/he... www.automaticwasher.org/cgi-bin/... "Even though we found machines often didn’t hit 60°C, manufacturers are not actually cheating the EU energy labels because there’s no requirement for the washing machine to reach the temperature stated on the control panel." www.which.co.uk/news/2013... |
Post# 1130201 , Reply# 24   10/2/2021 at 21:18 (935 days old) by Hippo (Oregon)   |   | |
Thank you, @Launderess. That is very informative albeit disappointing. Does anybody know if having Controlled Energy Consumption on or off for the Miele will lead to more accurate washing temperatures? |
Post# 1130202 , Reply# 25   10/2/2021 at 21:44 (935 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Post# 1130210 , Reply# 28   10/2/2021 at 23:14 (935 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Miele swore up and down for years they would never bring a 120v washing machine to USA. Things were always going to be 208v-240v (well 120v/208v-240v at least) or a host of reasons. That began to go by wayside for various reasons.
Don't know about 12XX washers, but 48XX, 30XX and now W1 series of washing machines all are 120v only. Indeed Miele announced a while back they no longer would sell 208v-240v washing machines in North America as part of domestic offerings. Commercial things like Little Giant washers are another matter. All Miele 120v washer require connection to both hot and cold inlets. When set to default programming and varies by cycle washer will take in warm (as combining hot and cold), and so forth, then heat to proper temp. This is a nod to fact many North American homes have large storage tank or other means of ample hot water on demand. Heating elements on these washers is low, IIRC W30XX are barely 1kW. You can change programming for these washers to "cold fill", but then things get interesting. Depending upon such variables as incoming tap cold water temp, set desired temp and washers' programming set temp may or may not be achieved. To be fair older Miele washing machines have always required connecting to both hot and cold taps. If you wanted to hook them up to cold fill only, you still needed (as above) to use a "Y" connector. But those machines with 208v-240v power and heating elements at or over 2 kW could easily take tap cold water to 86F, 104F within short period of time. This even if using cycles that used more water for washing such as delicates or wool. Hot water either filling from taps or heated by washing machine uses energy. My guess is by using hot water from taps is more about reducing work load on washing machine than anything else. I mean with certain short cycles it just won't be possible to heat cold to very chilly tap water to say 86F or 104F using puny 1kW heating power. Well not unless you extend heating phase of cycle by using thermostop or something. Since by nature delicate and woolens cycles are for things not meant to be washed very long, there are limits. |
Post# 1130215 , Reply# 29   10/3/2021 at 03:10 (935 days old) by Logixx (Germany)   |   | |
According to this manual, temp increase adds 5°C to the Cotton and Minimum Iron cycles.
fliphtml5.com/jknmy/kxha... |
Post# 1130223 , Reply# 30   10/3/2021 at 05:12 (935 days old) by AquaCycle (West Yorkshire, UK)   |   | |
I had a Miele W562 for 10 years and it was a lovely machine. I couldn’t fault it at all. I upgraded to a W1 machine - a WCG120 XL.
BIG mistake. It have very bizarre programming. 1. The express cycle with only 1 rinse was near useless. I don’t use it often but it’s a handy feature to have for freshening up a small load. 2. The cottons cycle was 2:44 for no fuzzy logic. If the machine sensed a smaller load, which it very rarely did, instead of adjusting the time properly like my old machine, it would default to the short option. 3. On cottons short, the rinsing was appalling. It would fill as the machine ramped down from spin but as soon as the water level was reached, it would pump out. The rinses lasted about 3 minutes. And it only did 2. 4. Minimum Iron was a much more reasonable cycle at 1:58 with 3 rinses BUT if the machine detected it had anything more than a full load in it, it would abort the cycle at the end of the main wash. 5. In the year and a half that I had it, I had Miele out to it 3 times. The first time because water was pooling on the door seal and running onto the floor when I opened the door, the second and third times were for excessive noise. See link below. It sounded like it was trying to vibrate its way into next door most of the time. And yes, the machine was level and the transit bolts were removed. I sold both the washer and dryer and bought a Siemens set last April, which are both fabulous. CLICK HERE TO GO TO AquaCycle's LINK
Post# 1130319 , Reply# 31   10/4/2021 at 08:55 (933 days old) by Rolls_rapide (.)   |   | |
Do they have a blue, or is it white, display? Bosch machines are red digits - and nigh on impossible to read clearly with failing eyesight. I don't know why some manufacturers can't grasp that fact. |
Post# 1130341 , Reply# 32   10/4/2021 at 11:43 (933 days old) by ozzie908 (Lincoln UK)   |   | |
Post# 1130465 , Reply# 34   10/5/2021 at 15:56 (932 days old) by AquaCycle (West Yorkshire, UK)   |   | |
Post# 1130507 , Reply# 35   10/6/2021 at 05:46 (932 days old) by Rolls_rapide (.)   |   | |
Thanks! |
Post# 1132605 , Reply# 39   11/3/2021 at 17:06 (903 days old) by mielerod69 (Australia)   |   | |
Post# 1133854 , Reply# 42   11/18/2021 at 04:59 (889 days old) by Brisnat81 (Brisbane Australia)   |   | |
Miele did the same when they replaced my twin dos module, they halved both formulas as apparently the reccomended dose was way to high. I’ve had no issues with cleaning performance since. |
Post# 1133912 , Reply# 45   11/18/2021 at 23:40 (888 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
On laundry product label often is a clear indication it contains enzymes. That or perhaps pH is so high (alkaline) would harm either fiber, but don't see anything out of ordinary in picture posted above.
It would be quite odd for Miele's Ultraphase detergent to go non-bio. Nearly all top shelf laundry detergents sold in USA and Europe at least all contain enzymes, often advanced cocktails of same to enhance performance. Indeed to get optimal results when laundering in warm to cool (or cold) water you need enzymes. Am going to leave UK and that whole "non-bio" drama on sidelines for purposes of this discussion. *LOL* |
Post# 1134010 , Reply# 48   11/20/2021 at 00:38 (887 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
IIRC "Normal" cycle on washing machines sold in USA is often the last choice one should use. By federal regulations that is the default cycle with low energy use (ready puny water levels and so forth), and also by regulations cannot be altered much if at all.
Happily thanks to modern machines being wholly computer controlled offering a wealth of cycle options isn't an issue. There usually are several cycles other than "Normal/Cottons/Linens" that will do what is wanted. |
