Thread Number: 88391
BOL kenmore confusion |
Post# 1129561 , Reply# 1   9/25/2021 at 10:45 (942 days old) by Repairguy (Danbury, Texas)   |   | |
The easiest way by picture is to either see the opening with the agitator or see the back of the machine. The back of a belt drive will have the service opening while the direct drive will be a solid panel. The agitator in a belt drive will be either a super roto swirl or a gold straight vane like the 29” standard capacity machines had. The belt drive version is probably going to be a lot harder to find than the direct drive but the are neat to have. I only recall seeing one in the many years of service and I brought it home 20 years ago and it still sits in the same spot I’m ashamed to say. Hope you find one.
Post# 1129564 , Reply# 2   9/25/2021 at 11:14 (942 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1129700 , Reply# 3   9/26/2021 at 22:11 (941 days old) by jeb (Mansfield Ohiio)   |   | |
D.D. lid is almost the same size as the top of the washer. A B.D. will have a smaller lid, with about 4 inches of top in front and on sides that is not lid. |
Post# 1129724 , Reply# 4   9/27/2021 at 09:23 (940 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1129793 , Reply# 5   9/27/2021 at 20:59 (940 days old) by Repairguy (Danbury, Texas)   |   | |
After going through the archives I found that the lid is larger on the direct drive models. The lid on the direct drive models is really close to the raised edge around the top of the machine. On the belt drives there is visibly more space between the lid and the raised edge of the top of the machine. The first 2 are direct drive and the third picture is a belt drive.
