Thread Number: 88414
/ Tag: Wringer Washers
What hose do I need for a Maytag e2l wringer Washer |
Post# 1129766 , Reply# 1   9/27/2021 at 16:15 (938 days old) by bradross (New Westminster, BC., Canada)   |   | |
Hey "Slim Jim",
The hoses do occasionally appear online on various auction sites, but they're usually fairly expensive. It is possible to make your own, but you will need to detach the end nozzle. There is an expansion ring inside that is impossible to remove without destroying it. So once you've got a length of replacement hose, you will need to get some strong adhesive to fix it back onto the hose. When I was faced with this task, I went to a hose supply store and got some that is used for fuel tanks (like for those portable ones you see on pick-up trucks). The hose was perfect for the task - flexible but VERY thick and strong. And just the right diameter for the nozzle. |
Post# 1129767 , Reply# 2   9/27/2021 at 16:20 (938 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Post# 1129775 , Reply# 3   9/27/2021 at 17:11 (938 days old) by MrSlimJim (Pittsburgh )   |   | |
Thanks for helping |
