Thread Number: 88498
AEG to launch pod-dispenser washers in the EU |
Post# 1130544 , Reply# 1   10/6/2021 at 15:52 (904 days old) by Logixx (Germany)   |   | |
Post# 1130554 , Reply# 2   10/6/2021 at 17:19 (904 days old) by appnut (TX)   |   | |
Post# 1130712 , Reply# 4   10/8/2021 at 14:13 (902 days old) by henene4 (Heidenheim a.d. Brenz (Germany))   |   | |
I think the pod dispenser makes a whole lot more sense in regard to the ÖkoMix system. Pre-dissolving detergents etc. The 7000 series machine has a MyMix 69min cycle. So ÖkoMix without any recirculation system, just 10min longer. |
Post# 1130744 , Reply# 5   10/9/2021 at 03:14 (901 days old) by stevefromsydney (London)   |   | |
I noticed that they've stopped selling the TOL machine that I have with the touch & swipe screen ( L9FEA966C ) I wonder why as it had 5 star reviews on all sellers review pages? |
Post# 1130800 , Reply# 6   10/10/2021 at 07:00 (900 days old) by Rolls_rapide (.)   |   | |
I see that the 8000 machine in the pictures seems to have a plastic backplate. |
Post# 1130801 , Reply# 7   10/10/2021 at 07:29 (900 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
" I'm not sure what the point of putting a pod into the drawer really is, it's so much easier to chuck it in the drum.."
PODS of all sorts have a nasty habit of getting stuck in boot. There contents in full or part will remain often for good duration if not all of wash. Well at least until plastic film dissolves. Since many machines aren't easily opened if at all once cycle is started, if you miss what window there is then that pod will have to remain where it is. Maybe if water level is low enough you can stop washer and using emergency door release open things up without causing a flood, but otherwise.... For PODS that are liquid only have resorted to snipping off corner, then squeezing contents into dispenser cap saved from Ariel Excell gel. Bung that lot into washer and that's that. OTOH PODS with chambers of dry and wet ingredients cannot be handled thus so. Then have to watch things and hope thing doesn't end up getting caught in boot, and or not dissolving totally where it should. As you might tell from this post am not a huge fan of PODS.... Wait I tell a lie.. Like them for when doing loads at local laundromat. Put POD in dispenser then poke it with a pen or something so it will break apart and go down into tub. Those SQ washers have a short (less than two minutes) pre-wash. If you put PODs in with laundry much of product will get flushed down drain when pre-wash water empties. And since cannot open door until machine is finished.... |
