Thread Number: 88543
LG WM3600VHA - Water left in drum |
Post# 1130975 , Reply# 1   10/11/2021 at 22:47 (920 days old) by powerfin64 (Yakima, Washington)   |   | |
drain the pump filter, which is on front bottom left side of the washer with a little door.
There is a little hose with a plug, that you will need to undo and drain.(use a bucket, there will be a fair amount of water in the pump) then unscrew the pump filter, clean it if it's needed. Screw back in the filter, put the plug back in the hose, your done. |
Post# 1130999 , Reply# 2   10/12/2021 at 05:53 (920 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 1131046 , Reply# 4   10/13/2021 at 08:56 (919 days old) by Pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
