Thread Number: 88614
1980's simpson delta S top loader - removing agitator? |
Post# 1131544 , Reply# 1   10/20/2021 at 22:48 (917 days old) by drummerboy928 (Illinois)   |   | |
I’m not familiar with these machines at all, but it appears to be similar to the agitator on the older Maytag machines. If that’s the case, then there should be a small set screw towards the base on the side of the agitator. If that’s the case, then all you’d need to do is loosen the set screw a few turns and the agitator should pull off.
Post# 1131545 , Reply# 2   10/20/2021 at 23:19 (917 days old) by HobartHero (New York)   |   | |
Post# 1131566 , Reply# 4   10/21/2021 at 06:17 (917 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
A warm welcome to Automatic Washer Nic, hope you get your Simpson washing machine sorted and its just grime build up rather than a new oil seal required.
I managed to pick up a later machine that was brought back over here when the family moved back to the UK having emigrated in the 60`s with Pilkingtons Glassworks. It was a fun machine to use, I had never seen a transmission like it with what Tom Turbomatic told me looked like a Whirlpool World Series washer mechanism. Morning Chris (Gizmo) where does this model I had fit into the line up then ? was it just the plastic inner & outer tub that had the agitator screwed onto the baseplate ? I do remember that removing nut as it was the first time I had to purchase a snap on tools long extension socket to remove the tall agitator. |
