Thread Number: 88670
Onboard Heater? |
Post# 1132068   10/27/2021 at 15:11 (910 days old) by IIIJohnnyMacIII (North Carolina)   |   | |
I am going to be purchasing a front load washer with prewash. I've read some of you wouldn't purchase a front load washer without an onboard heater. I was wondering if I would benefit from narrowing my search down to a washing machine that had an onboard heater.
My hot water heater is set to 140 degrees next to my washing machine. The only thing I wash in hot water are my whites and I use bleach when I do them. I wash everything else on warm, because I'm afraid of color bleeding and shrinking. From what I've gleaned thus far in my research is the heater only comes on when using allergen/sanitary/whites cycles. It doesn't come on periodically to keep water at "warm" temperatures when using other cycles. Is this true or are there brands out there, that when you set the machine to warm, it keeps the water at 90-100ish degrees throughout the wash cycle? If so, I would definitely be interested in them, because I could see where water temps could fall when using so little water for long periods of time and "warm" cycles turning into "cool" cycles. Thanks. |
Post# 1132122 , Reply# 3   10/27/2021 at 23:16 (909 days old) by Egress (Oregon)   |   | |
I believe my LG kicks it on to boost temps on the warm temp. I've opened the door after a load to find slightly warm laundry even after 2 cold rinses. |
Post# 1132123 , Reply# 4   10/27/2021 at 23:22 (909 days old) by appnut (TX)   |   | |
Post# 1132158 , Reply# 5   10/28/2021 at 08:09 (909 days old) by IIIJohnnyMacIII (North Carolina)   |   | |
Post# 1132162 , Reply# 6   10/28/2021 at 08:21 (909 days old) by Frigidaireguy (Wiston-Salem, NC)   |   | |
Johnny Where are you located in North Carolina ??? I live in Winston-Salem and there are several member that live in the area. We would love to have you visit. Bob |
Post# 1132163 , Reply# 7   10/28/2021 at 08:24 (909 days old) by Pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
i would reccomend this maytag but it also depends on how much you went to pay capacety but here the info www.maytag.ca/en_ca/washe...
Post# 1132290 , Reply# 9   10/29/2021 at 17:40 (908 days old) by vacerator (Macomb, Michigan)   |   | |
in a Samsung does activate on NORMAL when Steam or HOT is selected. The pumped out wash water is hotter on HOT than on Steam. |
Post# 1132613 , Reply# 10   11/3/2021 at 18:26 (902 days old) by IIIJohnnyMacIII (North Carolina)   |   | |
Post# 1132624 , Reply# 11   11/3/2021 at 19:23 (902 days old) by mark_wpduet (Lexington KY)   |   | |
OK....from everything I've seen, I would get an LG FL washer with a heater but more importantly a model that has turbo wash....
I have zero experience from LG, I just like to keep up with what's out there, how they operate... According to Eugene (I think that's his name) he really REALLY likes LG. He takes them apart to show how easy it is and how easy they are to repair. Based on seeing how they wash from youtube videos.....and the fact that he recommends them...that's the brand I would get.... There are models with a heater but without turbo wash that are still good. Turbo wash is just so much better with the recirculation. |
