Thread Number: 88798
GE Potscrubber vs BOTL GE? |
Post# 1133522   11/14/2021 at 13:27 (892 days old) by IIIJohnnyMacIII (North Carolina)   |   | |
Post# 1133526 , Reply# 1   11/14/2021 at 14:55 (892 days old) by appnut (TX)   |   | |
Post# 1133567 , Reply# 3   11/14/2021 at 23:36 (891 days old) by murando531 (Augusta, Georgia - US)   |   | |
These BOL GEs are found in mass numbers across the US in starter homes and apartments, and they’re horrible. We had a Nautilus back in the last years before moving out of my parents’, and I already had a low to moderate opinion of it, but it cleaned circles around these things. The top rack is the worst offender. No tines at all, just bent rack wire to kinda lay things against one another and hope they stay put. Then the lack of a ceiling spray arm, so grit collected in the tops of glasses is just a given. Then there’s the wash arm speed, which for some reason is twice as fast as the normal rotation of a lower arm in any other machine, which means it not only sounds…wrong, it also isn’t thorough. And, like stated above, the filtration disk is apparently there for looks, as it’s only fed by a little offshoot under the wash arm, so it barely even counts as passive filtering. Pair that with not even a layer of tissue paper for insulation inside the door or over the tub and you might as well get a big Rubbermaid tote and a dish drainer and a spinning lawn sprinkler before spending $250-300 on these things.
