Thread Number: 88840
Amana LW8203W2 Noise/Pump |
Post# 1134077 , Reply# 1   11/20/2021 at 19:57 (886 days old) by Repairguy (Danbury, Texas)   |   | |
Is this in the spin cycle? The hardest part of changing a pump on these machines is if it is seized on the motor shaft. There are two screws at the bottom of the front cover. Remove these and swing the front panel out from the bottom to disengage the clips at the top. You have to remove the belt(it probably needs replacing), the two hoses on the pump, then remove the four bolts holding the motor on and remove the assembly so you can turn it upside down to get the pump off. I would run it with the front cover off to be sure the pump is leaking and not the main tub seal before doing anything.
Post# 1134085 , Reply# 2   11/20/2021 at 20:21 (886 days old) by nashman50 (Blairsville, PA)   |   | |
Yes, it's the spin cycle. It does seem to be the main tub seal as well. It's leaking right where the pump attaches. |
Post# 1134089 , Reply# 3   11/20/2021 at 20:41 (886 days old) by RP2813 (Sannazay)   |   | |
Post# 1134096 , Reply# 4   11/20/2021 at 21:09 (886 days old) by Repairguy (Danbury, Texas)   |   | |
If the main tub seal (on the bottom of the tub where the transmission goes through) is leaking this machine needs a major rebuild. Also need to pin down the noise before moving along with this project. It’s doable if you have some mechanical skills, time, and money to put into a machine that was built in the mid nineties. These machines were built like tanks but it’s probably impossible to find a service person who would be interested in a job like this.
You would need: seal kit the upper bearing the belt the pump |
Post# 1134101 , Reply# 5   11/20/2021 at 22:26 (886 days old) by nashman50 (Blairsville, PA)   |   | |
I could probably do it if I could find all of the correct parts, but I've never taken a washer apart before. My dad is a mechanic so most of my experience is on that end of things. |
Post# 1134102 , Reply# 6   11/20/2021 at 22:36 (886 days old) by Repairguy (Danbury, Texas)   |   | |
Post# 1134104 , Reply# 7   11/20/2021 at 22:52 (886 days old) by nashman50 (Blairsville, PA)   |   | |
Thank you!
Post# 1134165 , Reply# 8   11/21/2021 at 19:11 (885 days old) by Repairguy (Danbury, Texas)   |   | |
I would be absolutely sure the main tub seal is leaking before tackling that job. I also recommend using only genuine RSPC or Whirlpool parts as they were designed for the proper operation of these machines.
Belt RSPC 28808 Whirlpool WP28808 Pump RSPC 201566P Whirlpool 27001233 Seal kit Whirlpool R9900552 Bearing RSPC 27182 Whirlpool WP40004201P |
Post# 1134212 , Reply# 9   11/22/2021 at 10:06 (884 days old) by nashman50 (Blairsville, PA)   |   | |
Is it difficult to replace the main tub seal? |
Post# 1134214 , Reply# 10   11/22/2021 at 11:41 (884 days old) by Repairguy (Danbury, Texas)   |   | |
It can be. The hub is made out of a pewter material and usually crumbles making it difficult to get it off. This is probably the hardest part of the job. Replacing the bearing requires completely disassembling the machine but it’s usually not too difficult if you are mechanically inclined. This machine was built in 1995 and if it’s in decent shape underneath and the outer tub isn’t rusted out it could still have some good years left in it.
Post# 1134227 , Reply# 11   11/22/2021 at 14:07 (884 days old) by nashman50 (Blairsville, PA)   |   | |
It is basically the same as a newer Speed Queen? I've found some videos online that would probably help. |
Post# 1134228 , Reply# 12   11/22/2021 at 14:15 (884 days old) by nashman50 (Blairsville, PA)   |   | |
And do you need the drive bell puller? I have one for a car, but not specifically for a washing machine. |
Post# 1134234 , Reply# 13   11/22/2021 at 16:31 (884 days old) by Repairguy (Danbury, Texas)   |   | |
It is the same as a speed queen of the same age. Speed Queen machines today have a different seal and bearing setup than these machines did. Crude as it may be I was always able to place 2 claw hammers opposite each other with the claw ends under the lip of the bell and when you pull up on the handles it would pry the bell right off. Some came off easily and others were a pain but the majority of the time the hammers worked. I’m sure if you have a puller handy it will work as well.
Post# 1134365 , Reply# 14   11/23/2021 at 22:54 (883 days old) by nashman50 (Blairsville, PA)   |   | |
Thanks for your help! I ordered the parts yesterday so we are going to give it a shot. |
Post# 1135535 , Reply# 16   12/7/2021 at 13:06 (869 days old) by Repairguy (Danbury, Texas)   |   | |
Post# 1135549 , Reply# 17   12/7/2021 at 16:41 (869 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1136145 , Reply# 18   12/13/2021 at 22:22 (863 days old) by nashman50 (Blairsville, PA)   |   | |
It looked like a bunch of it was lying under the agitator. |
Post# 1136147 , Reply# 19   12/13/2021 at 23:27 (863 days old) by RP2813 (Sannazay)   |   | |
I think you'll be very pleased with your new front loader. They clean better and the tumbling action helps all of your laundered items last longer. I'm on my third FL set since 2007 -- by choice and/or circumstances, not because the first two had any issues -- and they are the oldest: Maytag Neptunes from 2004. They have become my favorite. |
