Thread Number: 88897
80's era Maytag Washer and Dryer |
Post# 1134647   11/26/2021 at 18:47 (878 days old) by Superwash (Cape Coral, FL)   |   | |
Hi! I have a chance to pick up these beauties this weekend. They look to be in great condition and were in use until recently. The new homeowners don't need them.
So, are they worth it? I was wondering if they're still Maytag or Whirlpool built. Will I be able to still get parts? I appreciate your advice. Thanks! |
Post# 1134651 , Reply# 1   11/26/2021 at 18:58 (878 days old) by pulltostart (Mobile, AL)   |   | |
Post# 1134653 , Reply# 2   11/26/2021 at 19:10 (878 days old) by qsd-dan (West)   |   | |
Post# 1134661 , Reply# 3   11/26/2021 at 20:06 (878 days old) by Superwash (Cape Coral, FL)   |   | |
Post# 1134663 , Reply# 4   11/26/2021 at 20:16 (878 days old) by RP2813 (Sannazay)   |   | |
Post# 1134664 , Reply# 5   11/26/2021 at 20:16 (878 days old) by Washerlover (The Big Island, Hawai’i)   |   | |
Post# 1134668 , Reply# 6   11/26/2021 at 21:14 (878 days old) by qsd-dan (West)   |   | |
The dryer design goes back to 1976 for residential use (about 1973 for commercial use). Some minor oddities changed over the years but not much. This platform ended in 2006.
The washer got a new transmission/agitator change in July, 1989. Other than that, besides the updated motor carriage and twist lock fill flume hose (mid 80's) and large capacity tub (1966), it's basically a 1950's Maytag helical washer. |
Post# 1134670 , Reply# 7   11/26/2021 at 21:48 (878 days old) by Superwash (Cape Coral, FL)   |   | |
You have convinced me to proceed with getting them. I wanted some that was vintage but still reliable. These will replace the junky Samsung's left by the previous home owner. They are only 3 years old and I've been getting errors on the washer (plus it sounds like it's going to blow it's transmission just anytime). It barely swirls the clothes around and I don't overload. I just don't like the HE washers with the wash plate.
Thanks everyone for your input. It is greatly appreciated! |
Post# 1134681 , Reply# 9   11/26/2021 at 22:58 (878 days old) by Yogitunes (New Jersey)   |   | |
Post# 1134684 , Reply# 10   11/26/2021 at 23:04 (878 days old) by Good-Shepherd (New Jersey)   |   | |
I think this washer still has the removable lint filter in the agitator. |
Post# 1134690 , Reply# 11   11/27/2021 at 00:09 (878 days old) by RP2813 (Sannazay)   |   | |
1) Truck the machines from the side only. This may seem like common sense but there has been no shortage of Maytag washers pictured here over the years that have had dents in the front panel from a hand truck or appliance dolly.
2) The washer is quite heavy. Bring help if you have any reservations about being able to load it onto a truck or into a van or station wagon by yourself. |
Post# 1134709 , Reply# 12   11/27/2021 at 10:42 (878 days old) by sprog (Boston)   |   | |
In addition to the wonderful advice already given,
I usually open the front of the washer (while unplugged) check the damper pads and motor slides for condition/lubrication. It's also a great time to inspect the hoses for any evidence of leaks. I have the same washer as a daily driver and it's a TANK. Good luck! |
Post# 1134726 , Reply# 14   11/27/2021 at 15:40 (877 days old) by Superwash (Cape Coral, FL)   |   | |
Post# 1134784 , Reply# 15   11/28/2021 at 15:43 (876 days old) by Superwash (Cape Coral, FL)   |   | |
I picked up the Maytags today. They look better in person than they did from the photos! Both washer and dryer are in mint condition. No scratches dents or rust anywhere .
I already did a water leak test in the driveway. The washer agitated and spun the water out without any issue. No leaks no sign of leakage when the front cover was taken off. I set it over on its back and while the two belts look pretty good, I'm going to go ahead and buy new belts. Once the belts are installed I will install the set and let everyone know how they perform. Yes the wind filter is inside the agitator and it was gross. Lol. Thanks everyone for the valuable advice. Great group! |
Post# 1134785 , Reply# 16   11/28/2021 at 16:02 (876 days old) by appnut (TX)   |   | |
Post# 1134812 , Reply# 18   11/28/2021 at 19:29 (876 days old) by Superwash (Cape Coral, FL)   |   | |
Post# 1134817 , Reply# 19   11/28/2021 at 20:24 (876 days old) by Good-Shepherd (New Jersey)   |   | |
Come on man, living SW Florida, you can take your time wearing shorts and a cool drink in your hand. |
Post# 1134819 , Reply# 20   11/28/2021 at 20:28 (876 days old) by Superwash (Cape Coral, FL)   |   | |
Post# 1134820 , Reply# 21   11/28/2021 at 20:31 (876 days old) by Superwash (Cape Coral, FL)   |   | |
I just watched a few YouTube videos, and now I'm not so intimidated. It does look pretty easy to check. I'm hoping I don't have to replace them.
Thanks again! This post was last edited 11/28/2021 at 22:03 |
Post# 1135036 , Reply# 22   12/1/2021 at 23:36 (873 days old) by Superwash (Cape Coral, FL)   |   | |
The Maytags are in place and seem to be working fine. I did run a water leak test in the driveway, after getting them off the trailer. The washer perform just fine.
I just ran hot water and bleach through the washer. The wash cycle in first spin did perfect. It just finished rinsing and is draining the water now . I'm still going to replace the belts just to be safe. I also noticed that the left front leveling leg will probably need to be replaced. But I do have the washer level, both front to back, inside to side. I'll run a load of light laundry in it tomorrow morning to see how she does. By the way, the dryer works fine. Heats right up, but I guess I'll know when I throw some wet stuff in and see how it will do with drying. Thanks everyone for your advice. I really appreciate you guys! |
Post# 1135039 , Reply# 23   12/1/2021 at 23:43 (873 days old) by appnut (TX)   |   | |
Post# 1135080 , Reply# 24   12/2/2021 at 13:03 (873 days old) by Hippiedoll ( arizona )   |   | |
CONGRATULATIONS on getting a Maytag set! I am not very familiar with this era of Maytags, I'm more familiar with the center-dial models. But from what I've seen, some of these later model Maytags have a couple more options/features added compared to the center-dial models (2nd rinse, infinite water level), and I'm not sure if maybe another option added in the timer knob of the model that would be similar to a 608?
So CONGRATULATIONS on your Maytag set, I'm glad they seem to be in Plug & Play condition and ready to use for you. Doing the HAPPY DANCE for you on this side of the computer! 🥳😊 |
