Thread Number: 88899
/ Tag: Vintage Dishwashers
Porcelain repair. |
Post# 1134652   11/26/2021 at 18:58 (875 days old) by Cam2s (Nebraska)   |   | |
Any tips on a porcelain chip repair? I was just going to use some water weld over the spot. There doesn’t appear to be any rust or bubbling.
Post# 1134723 , Reply# 1   11/27/2021 at 14:58 (874 days old) by firedome (Binghamton NY & Lake Champlain VT)   |   | |
Post# 1134734 , Reply# 2   11/27/2021 at 18:21 (874 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 1134743 , Reply# 3   11/27/2021 at 21:02 (874 days old) by bradfordwhite (central U.S.)   |   | |
Dry clean it with a bit of fine steel wool being careful not to scratch the surrounding finish.
Then dab the area with rubbing alcohol to get off all dust and prep the area for which ever treatment above you plan to use. It's good that you're treating the spot while it's small. IMO- I do see a small bit of rust there. |
