Thread Number: 88904
1968 Frigidaire "giraffe" dryer |
Post# 1134707   11/27/2021 at 10:33 (879 days old) by bradfordwhite (central U.S.)   |   | |
I remember that timer dial, the panel color scheme and that start button as a childhood friend had the normal height version.
CLICK HERE TO GO TO bradfordwhite's LINK
Post# 1134708 , Reply# 1   11/27/2021 at 10:36 (879 days old) by DaveAMKrayoGuy (Oak Park, MI)   |   | |
Post# 1134710 , Reply# 2   11/27/2021 at 10:42 (879 days old) by bradfordwhite (central U.S.)   |   | |
Post# 1134714 , Reply# 3   11/27/2021 at 11:01 (879 days old) by Maytag85 (Sean A806)   |   | |
Post# 1134716 , Reply# 4   11/27/2021 at 11:47 (879 days old) by petek (Ontari ari ari O )   |   | |
Post# 1134718 , Reply# 5   11/27/2021 at 12:51 (879 days old) by appnut (TX)   |   | |
Post# 1135075 , Reply# 7   12/2/2021 at 12:26 (874 days old) by Maytag85 (Sean A806)   |   | |
This is what the set would have looked like. Screenshot from when I was surfing through the archives a few years ago.
Post# 1135081 , Reply# 8   12/2/2021 at 13:19 (873 days old) by appnut (TX)   |   | |
That's the exact set I saw at Hemisfaire in San Antonio in 1968. Notice the storage area for laundry aids. At age 14 and near-sighted, these were eye-level for me and I loved being able to see the detail without having to lean over a washer or dryer.
Notice the 4 little knobs toward the left--that's for the variable wash and spin speeds and selectable wash and rinse temperatures. This model also includes the variable water level, meaning it's not dependent on timed fill, found on the Custom Imperial Frigiaires beginning in 1966 or 1967. Also, there were "High Fashion" versions for a range too. Sean, thank you for digging this up!! This post was last edited 12/02/2021 at 13:56 |
Post# 1135085 , Reply# 9   12/2/2021 at 13:51 (873 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1135086 , Reply# 10   12/2/2021 at 13:58 (873 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1135087 , Reply# 11   12/2/2021 at 14:10 (873 days old) by appnut (TX)   |   | |
Post# 1135110 , Reply# 12   12/2/2021 at 18:30 (873 days old) by bradfordwhite (central U.S.)   |   | |
If you have an FB accnt you could contact the party. This listing is a couple months old so...
He had a few interesting 50s/60s pieces. ----- Can not believe they took a pic with the machines in a bunk bed. Look at the ladder on the other side. Those spindles were going to hold up a floor that is highly susceptible to vibration from the machines? It made one think, that's for sure. |
Post# 1135120 , Reply# 13   12/2/2021 at 21:07 (873 days old) by appnut (TX)   |   | |
Post# 1135181 , Reply# 14   12/3/2021 at 16:24 (872 days old) by Washerlover (The Big Island, Hawai’i)   |   | |
Post# 1135227 , Reply# 15   12/3/2021 at 23:30 (872 days old) by thomasortega (El Pueblo de Nuestra Señora de Los Angeles de Porciúncula)   |   | |
Simple answer: the same way her arms would reach the controls on a splashguard-type panel, just the angle changes, basically. |
Post# 1135231 , Reply# 16   12/4/2021 at 00:53 (872 days old) by bradfordwhite (central U.S.)   |   | |
The height of prospective users is not the only thing that would be concerning. I'm still trying to figure out if that entire pack panel is removable for shipping.
Another factor that probably factored into axing these- picture if you will, either of these machines operating, and vibrating under normal usage as they will. There is always cabinet movement even if just slight on the dryer, but can you imagine that flimsy back panel jiggling during the spin cycle? They better have had lock washers on all the panel screws because even with a stiff support post on the corners, those panels must have looked unusual flopping around when the machine was operating. |
Post# 1135272 , Reply# 17   12/4/2021 at 15:31 (871 days old) by frigidareu (Brunswick, Ohio)   |   | |
Those are my "Dream Machines". Never got to see them in person just saw them in magazine ads. |
Post# 1135347 , Reply# 18   12/5/2021 at 13:22 (870 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 1135408 , Reply# 20   12/5/2021 at 21:29 (870 days old) by bradfordwhite (central U.S.)   |   | |
Post# 1135410 , Reply# 21   12/5/2021 at 22:12 (870 days old) by Maytag85 (Sean A806)   |   | |
I read through some of the thread, seems like the variable speed was very problematic and was a pain to fix. If Whirlpool wanted variable speeds on their washer, they could have used something similar to a drum brake on the transmission input shaft and could have controlled the clutching by adjusting the tension of the springs with a cable going to it.
