Thread Number: 88927
Maytag A712 Is Dying |
Post# 1134915 , Reply# 1   11/30/2021 at 21:09 (871 days old) by qsd-dan (West)   |   | |
Check the stop lug, screw, and washer. Something down there may have loosened up or broke.
Also, verify the motor pulley isn't slipping by twisting the pump/transmission pulleys in opposite directions. This post was last edited 11/30/2021 at 21:47 |
Post# 1135209 , Reply# 2   12/3/2021 at 20:18 (868 days old) by scrubflex (bronx, new york)   |   | |
Thanks Dan, here are pics of what the tip of the transmission end...the stop lug...washer and screw look like. If I can repair it tonight I will. |
Post# 1135223 , Reply# 3   12/3/2021 at 22:59 (868 days old) by qsd-dan (West)   |   | |
Was the stop, washer, and screw all in place and properly adjusted? They look pretty rusted up. Make sure to apply some grease on these parts and a little inside the rubber cap before reinstalling it.
Post# 1135257 , Reply# 4   12/4/2021 at 12:10 (867 days old) by scrubflex (bronx, new york)   |   | |
They all were in place...had to pry everything loose...not a struggle...all seemly was in place but, I could turn and spin the transmission (washtub) both ways |
Post# 1135258 , Reply# 5   12/4/2021 at 12:19 (867 days old) by scrubflex (bronx, new york)   |   | |
Also, Dan is it possible to get two different agitators permanently attached together? If so, do you have any idea where to go? I have an idea |
Post# 1135259 , Reply# 6   12/4/2021 at 12:22 (867 days old) by scrubflex (bronx, new york)   |   | |
And, the washer and screw are stuck together |
Post# 1135270 , Reply# 7   12/4/2021 at 15:23 (867 days old) by scrubflex (bronx, new york)   |   | |
Hey Dan the transmission pulley is rusted to the lower drive shaft...cannot remove trans pulley |
Post# 1135280 , Reply# 8   12/4/2021 at 16:37 (867 days old) by qsd-dan (West)   |   | |
Post# 1135283 , Reply# 9   12/4/2021 at 16:52 (867 days old) by scrubflex (bronx, new york)   |   | |
Will do...Thank you...what about (is it possible to get two different agitators permanently attached together? If so, do you have any idea where to go?) |
Post# 1135287 , Reply# 10   12/4/2021 at 17:34 (867 days old) by qsd-dan (West)   |   | |
Post# 1135289 , Reply# 11   12/4/2021 at 17:46 (867 days old) by scrubflex (bronx, new york)   |   | |
Actually, I'd like to attach an upper agitator column to a lower agitator skirt. If it can be done, I'll create something that should have been done.:D |
Post# 1135290 , Reply# 12   12/4/2021 at 18:24 (867 days old) by qsd-dan (West)   |   | |
Post# 1135294 , Reply# 13   12/4/2021 at 18:56 (867 days old) by scrubflex (bronx, new york)   |   | |
To adapt for use in a washer |
Post# 1135369 , Reply# 14   12/5/2021 at 15:09 (866 days old) by scrubflex (bronx, new york)   |   | |
The rust refuses to release the helical drive shaft, Dan. It's been two days since using the oil. |
Post# 1135401 , Reply# 15   12/5/2021 at 20:16 (866 days old) by qsd-dan (West)   |   | |
Post# 1135409 , Reply# 16   12/5/2021 at 21:32 (866 days old) by scrubflex (bronx, new york)   |   | |
Alrighty...what do you say about the agitator? Is it possible?...how soon can I get made? |
Post# 1135440 , Reply# 17   12/6/2021 at 09:12 (865 days old) by scrubflex (bronx, new york)   |   | |
Unfortunately, the rust in the transmission pulley is refusing to release the drive shaft...although, saturated with 3 different penetrating spray oils |
Post# 1135445 , Reply# 18   12/6/2021 at 12:09 (865 days old) by robbinsandmyers (Conn)   |   | |
Post# 1135452 , Reply# 19   12/6/2021 at 14:11 (865 days old) by scrubflex (bronx, new york)   |   | |
Thanks robbinsandmyers, I will try it |
Post# 1135493 , Reply# 20   12/6/2021 at 21:08 (865 days old) by scrubflex (bronx, new york)   |   | |
The latest...transmission is leaking oil now...lying on the washer's back...holding the agitator and turning the pulley counter-clockwise after spray/soaking with 3 different rust penetrating oils...after 2 days...not successful |
Post# 1135514 , Reply# 21   12/7/2021 at 07:34 (864 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Hi Harry, what on earth happened to this washer that allowed the main drive pulley to get so corroded etc.
It looks like the machine sat in 4-6" of water for an extended time for this type of damage to happen.
The shaft and pulley are greased when assembled and I have never seen one that was even slightly dry let alone rusted together, what is the condition of the rest of this washer?
John |
Post# 1135543 , Reply# 23   12/7/2021 at 15:27 (864 days old) by scrubflex (bronx, new york)   |   | |
Any ideas how it could have been water corroded, John, Dan or...? |
Post# 1140875 , Reply# 25   2/1/2022 at 08:06 (808 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
This type of damage is a little unusual but something must be leaking from above,
The rusted bearing is not the radial bearing, this is a sealed ball bearing right above and set into the brake package, this bearing may also be damaged.
Try lubricating the release bearing and put every thing back together if the release bearing turns and is not too rough. If the washer works but roars at full spin speed you will likely need to replace the radial bearing and you may need to replace both.
You should watch carefully for leaks when you use this machine for a while.
Post# 1140877 , Reply# 26   2/1/2022 at 09:01 (808 days old) by scrubflex (bronx, new york)   |   | |
The tub bearing seal is new from the rebuilt...Here's a closer view John |
Post# 1141126 , Reply# 27   2/3/2022 at 21:05 (806 days old) by scrubflex (bronx, new york)   |   | |
The Radial Ball Bearing is not as damaged as I thought...it's rusty inside
Post# 1141127 , Reply# 28   2/3/2022 at 21:12 (806 days old) by scrubflex (bronx, new york)   |   | |
The Brake Rotor Bearing is terribly corroded...I'm going to replace it...as soon as I find one to buy...anyone has any to sell? |
Post# 1141128 , Reply# 29   2/3/2022 at 21:20 (806 days old) by scrubflex (bronx, new york)   |   | |
The transmission spline and helical shaft are rusted...what is the best thing to use for the rusting? Is it necessary to replace the brake package?
Post# 1141129 , Reply# 30   2/3/2022 at 21:24 (806 days old) by qsd-dan (West)   |   | |
Post# 1141165 , Reply# 32   2/4/2022 at 11:18 (805 days old) by qsd-dan (West)   |   | |
The threads on the helical shaft and splines for the brake package are coarse so you should be able to successfully use a rust remover/dissolver.
Finding a new 200835 pulley bearing will be a challenge. You'll probably have to source a used one from a donor machine.
If your 712 was built after June 1986, replace the lower lip seal. |
Post# 1141175 , Reply# 33   2/4/2022 at 12:10 (805 days old) by robbinsandmyers (Conn)   |   | |
Post# 1141264 , Reply# 36   2/5/2022 at 10:56 (804 days old) by scrubflex (bronx, new york)   |   | |
Just ordered the Radial Ball Bearing from 'LORAINFURNITURE' and who generously donated the Brake Rotor Bearing...AWESOME...thanks again lorainfurniture!!! |
Post# 1141306 , Reply# 37   2/5/2022 at 16:09 (804 days old) by Lorainfurniture (Cleveland )   |   | |
Glad I could help! |
Post# 1142541 , Reply# 39   2/18/2022 at 20:24 (791 days old) by scrubflex (bronx, new york)   |   | |
My 712 does not have a transmission lip seal |
