Thread Number: 88955
2021 Any Warm Rinse Front load Washers? |
Post# 1135204 , Reply# 1   12/3/2021 at 19:42 (867 days old) by appnut (TX)   |   | |
Post# 1135225 , Reply# 2   12/3/2021 at 23:03 (867 days old) by Moon1234 (Wisconsin)   |   | |
All Miele Professional washers offer warm water rinse. The eco Nazis have taken away that option for most “residential” washing machines. |
Post# 1135239 , Reply# 3   12/4/2021 at 03:37 (867 days old) by mrboilwash (Munich,Germany)   |   | |
In theory there shouldn`t be a huge problem with felting of wool because of a smallish temperature change from a lukewarm 30 °C or a warm 40 to a cold rinse.
I think if it was a problem most European washers would do a cool down in wool cycles before the first cold rinse as they do in permanent press cycles, but AFAIK they don`t. On the other hand if you use 60 °C hot water for wool as it`s typically done for dyeing this delicate fabric then you have to be very careful about temperature changes which means the dye bath should be heated slowly and then at best let it cool down all by itself. So I get the point of a FL with a warm rinse, but even if you can find one it would be most likely only the last rinse in warm water because of energy restrictions which again doesn`t do anything about temperature changes during the cycle. On a side note as a German I find the term eco Nazi a bit offensive. I know most folks who say so aren`t even aware of what they say but political correctness otherwise is a top priority on AW so why not for everyone? |
Post# 1135241 , Reply# 4   12/4/2021 at 05:07 (867 days old) by HobartHero (New York)   |   | |
Post# 1135242 , Reply# 5   12/4/2021 at 06:46 (867 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Post# 1135243 , Reply# 6   12/4/2021 at 07:38 (867 days old) by Pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
Post# 1135268 , Reply# 8   12/4/2021 at 14:35 (867 days old) by Logixx (Germany)   |   | |
