Thread Number: 89115
/ Tag: Classified Ad Finds
Westinghouse Laundromat Pair |
Post# 1136941   12/22/2021 at 22:15 (854 days old) by Repairguy (Danbury, Texas)   |   | |
In Saint Maries, ID
$700 For some reason I’m not good at being able to upload the photos from eBay ads. CLICK HERE TO GO TO Repairguy's LINK on eBay |
Post# 1136947 , Reply# 1   12/23/2021 at 02:25 (854 days old) by chachp (North Little Rock, AR)   |   | |
Post# 1136959 , Reply# 2   12/23/2021 at 08:45 (854 days old) by Repairguy (Danbury, Texas)   |   | |
Post# 1136967 , Reply# 3   12/23/2021 at 09:26 (854 days old) by eurekastar (Amarillo, Texas)   |   | |
Post# 1136989 , Reply# 4   12/23/2021 at 13:21 (854 days old) by DADoES (TX, U.S. of A.)   |   | |
I can't say about other browers. Firefox (desktop or laptop) has an easy way to save pics from eBay and Facebook and whichever other platforms work similarly. It sounds like a lot of steps but isn't when one gets a grip on the procedure. Click on the first photo to view it larger (overlay), right-click on the image and select Open Image in New Tab, which it will. Proceed to do that with each photo. Then switch to each tab in turn and either right-click and Save Image As or drag the image to wherever you wish to save it, such as a folder on the desktop or wherever you can find it when finished. Sometimes all the images are fed as the same filename so renaming each (such as 01, 02, 03, etc.) before saving the next can make for easier handling. You'll have all the images saved offline when done for dragging them into the post and submitting it, and can then delete the images and folder if not wanting to keep them. Can also optionally edit them if you have software for that before adding to the post. Best size for display on AW is no more than 900 pixels on the largest dimension, I resize to 875 pixels. Sometimes I crop-out extraneous area and tweak the contrast and sharpness. Some market platforms use page code to block right-clicking for saving the images but Firefox has a workaround that usually works, which I won't get into the details of it. |
Post# 1136990 , Reply# 5   12/23/2021 at 13:30 (854 days old) by appnut (TX)   |   | |
Post# 1137034 , Reply# 6   12/23/2021 at 17:56 (853 days old) by bradfordwhite (central U.S.)   |   | |
Post# 1137066 , Reply# 7   12/23/2021 at 20:58 (853 days old) by Repairguy (Danbury, Texas)   |   | |
Post# 1137076 , Reply# 8   12/23/2021 at 22:23 (853 days old) by CircleW (NE Cincinnati OH area)   |   | |
Bob, I hate to correct you, but photo #4 shows a white dryer drum that clearly has thousands of perforations. Was it just an inner liner? |
Post# 1137081 , Reply# 9   12/24/2021 at 00:05 (853 days old) by appnut (TX)   |   | |
Post# 1137085 , Reply# 10   12/24/2021 at 00:57 (853 days old) by Maytag85 (Sean A806)   |   | |
I’ve seen a Westinghouse dryer similar to that pop up for sale here in the Southern California area with a perforated drum a few years ago. Looks like Westinghouse changed the design in 1953 or 1954 to improve air flow along with making it easier to disassemble but I can’t say for certain since I am not familiar with Westinghouse machines of this era nor worked on one before.
Post# 1137098 , Reply# 11   12/24/2021 at 08:05 (853 days old) by turquoisedude (.)   |   | |
How odd about the perforated dryer drum - the 53 and 58 Westys in my collection both have the solid drum with perforations in the back. I'm going to guess that air flow was possibly too much when combined with the hot air inlet chute in the front of the drum.
Is it me or does it look like that washer has no door boot? And my public service reminder, if anyone gets these, be sure to bolt down the washer tub before moving it. Remember what happened to my very first L5 years ago... |
Post# 1137110 , Reply# 13   12/24/2021 at 11:17 (853 days old) by turquoisedude (.)   |   | |
Post# 1137130 , Reply# 14   12/24/2021 at 13:18 (853 days old) by eurekastar (Amarillo, Texas)   |   | |
Post# 1137152 , Reply# 16   12/24/2021 at 17:00 (852 days old) by Moparwash (Pittsburgh,PA )   |   | |
From 1951
