Thread Number: 89244
/ Tag: Vintage Dishwashers
Kitchenaid KUDA22 Superba Selectra Upper Arm Doesn't Spin |
Post# 1138346 , Reply# 1   1/3/2022 at 23:50 (815 days old) by Cam2s (Nebraska)   |   | |
Does the arm spin freely by hand all the way around? If yes then perhaps the feed pipe has broke or isn’t mating up properly. It may be getting some water but not enough to spin or clean properly. |
Post# 1138390 , Reply# 2   1/4/2022 at 10:49 (814 days old) by RP2813 (Sannazay)   |   | |
Post# 1138418 , Reply# 3   1/4/2022 at 16:19 (814 days old) by Dustin92 (Jackson, MI)   |   | |
What about a clogged fill valve not allowing in the proper amount of water? Try adding a gallon once the machine has stopped filling and see if the arm spins then. Should be filling almost to the bottom of the door. |
Post# 1138438 , Reply# 5   1/4/2022 at 19:24 (814 days old) by bradfordwhite (central U.S.)   |   | |
1. if the filter is clogged with gunk you'll need to remove that and clean it.
The pump being deprived of water won't be able to pump it. That makes sense right? 2. the wash arm its self may have gunk in the sprayer holes which will prevent it from turning. 3. The pump impeller may need replacing but I would give attention to the other two first. todayshomeowner.com/video/how-to...
