Thread Number: 89389
/ Tag: Classified Ad Finds
1968 RCA Whirlpool washer in Spokane |
Post# 1140008   1/21/2022 at 18:01 (818 days old) by jons1077 (Vancouver, Washington, USA)   |   | |
Post# 1140012 , Reply# 1   1/21/2022 at 18:36 (818 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 1140015 , Reply# 2   1/21/2022 at 19:18 (818 days old) by bradfordwhite (central U.S.)   |   | |
Post# 1140019 , Reply# 3   1/21/2022 at 19:30 (818 days old) by RP2813 (Sannazay)   |   | |
Post# 1140024 , Reply# 4   1/21/2022 at 20:05 (818 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1140040 , Reply# 5   1/21/2022 at 23:37 (818 days old) by Maytag85 (Sean A806)   |   | |
Post# 1140052 , Reply# 6   1/22/2022 at 02:16 (818 days old) by appnut (TX)   |   | |
Post# 1140057 , Reply# 7   1/22/2022 at 09:02 (818 days old) by Tasser (Baltimore Md)   |   | |
I have the matching dryer. If I wasn’t all the way across the country I’d grab it! |
Post# 1140065 , Reply# 9   1/22/2022 at 10:15 (818 days old) by DADoES (TX, U.S. of A.)   |   | |
Our 1962 WP didn't have a PP/WnW cycle. Hot/(Warm), Warm/(Warm), Cold/(Cold) temp choices. User guide advised for a cold rinse, set the temp control to Cold after the wash agitation begins. The 1976 Supreme 80 had 5 temp choices. PP and Knit did not override a warm rinse selection to cold, the user was expected to know the correct choice. RJ's '85/'86 Imperial 70 (five temp pushbuttons) also doesn't override to cold rinse on PP AFAIK. |
Post# 1140101 , Reply# 11   1/22/2022 at 17:49 (817 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1140105 , Reply# 12   1/22/2022 at 19:05 (817 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Warm rinse likely was a concession to those who still stuck with soap on wash day. Ivory Snow and some other products were still out there in late 1960's that were pure or mostly soap.
Warm water does give slightly better rinsing (detergent or soap)and extraction, which is why commercial laundries rarely rinse in cold water. Much would depend upon what temperature "cold" water is coming out of taps. During warmer months, especially hot summers around here tap water is around 85 or bit above degrees F. OTOH once temps drop and remain chilly tap water is quite cold indeed. SQ washers at local laundromat take hot water into FS dispenser and maybe one side, with cold as balance. Know this because one sees steam wafting up from dispenser as machines fill for final rinse. In any event warm rinses virtually vanished from domestic washing machines as energy crisis of 1970's rolled out. Finally warm water final rinse does lessen energy used by tumble driers or ironing (by hand or machine), and or pressing. Federal government, Consumer Reports and others pushing "energy saving" use of cold water for rinsing admitted as much, but would go on to say amount of energy saved was "minimal" compared to what was used to heat water for warm water rinsing. In their considered opinion cold water rinsing was just as good. |
Post# 1140749 , Reply# 13   1/30/2022 at 23:06 (809 days old) by jons1077 (Vancouver, Washington, USA)   |   | |
